Hello, my oscilloscope model is SDS2034. I want to turn on the decoding and signal generator functions of this oscilloscope to get the correct accessory serial number
Do you have a way?
Hello... first time post question. I've been following the blog for a while looking for a solution to re-enable the AWG for my SDS2104X.
Same issue as above.
I want to enable the AWG and other options if possible. The AWG is a priority.
Following the blog, I learned my scope does not have a built in web server.
And therefore, I cannot enable these options so easily, if at all.
I've had the scope for several years now and did not realize when I purchased it that the AWG was on a temporary license.
It was finally disabled about a month or so ago. I used it a lot and rarely turned it off.
Hopefully, someone can help. I didn't want to start a new topic as I'm pretty sure this has been covered in many threads.
But maybe there's a way I haven't seen yet.
Thanks very much!
