In the V1 software you have to select which option you are going to install otherwise the option key doesn't work. For some reason the firmware can't detect what kind of option you are installing ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
OMG lol, I'll give that a try... that's funny as hell.
Also kinda sad... ![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Chris
*** Update: Nope this made no difference, I would have felt like an idiot.
Sorry, I haven't got any magic to offer you.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
All I can suggest is to double check the SN and ID #'s you sent for the option code were correct.
The "enable" codes you got back should look something like this: xxxx-xxxx-xxxx-xxxx and there be one for each option acquired.
When you enter your codes do you get any indication of error or confirmation of entry?
Little walk through:
In the Option
Information window there will be a box listing all 4 options and their current status; Trial, Expired or Permanent and when an Option is installed correctly the License Type will be
Permanent and the trial counter (Remain Times) will show
XXThe options NOT permanently enabled will be highlighted in the Option
Type popup and the "installed" options not highlighted.
As each Option is selected in the Type popup the 2nd window will display
Install or
Installed as another indicator of the Options status.
Option enable codes are entered in a popup window after
Install is selected for each option NOT installed.
