Hi there!
My SDS1104X-E (hacked) gets hung frequently in XY mode, which is very annoying.
Look at the next image:
BC109B transistor in a Curve TracerSo far so good. CH2 (Y) responds flawlessly but if I try to reduce horizontal volts per division with the X channel (CH1) it freezes with no buttons or knobs responding at all. The only way to get out of that is to press the ON button for some seconds until it shuts off. In this case, if I switch from 2V to 1V it hangs completely.
On the other hand, if I go the other way up, i.e.: from 2V to 5V, it behaves correctly. Back to 2V, OK again, but if I try to go to 1V, it hangs again.
What's worse is that it is not the only occurrence. If I switch from different acquisition modes, it hangs up again.
The first occurrence happens always, the second, just sometimes. Very annoying
EDIT:
Ooops, I forgot to tell that:
OS: 8.3
FW: 6.1.37R9
HW: 01.05
FPGA: 2021-11-08
