New Firmware Version: V6.1.37R9
https://int.siglent.com/download/firmwares/?ProId=12
What's new? It must be my broken English but I didn't understand much from the release note.
What's new? It must be my broken English but I didn't understand much from the release note.Fixed the problem: The skew of the two ADCs is not accuracy for hardware of 09 version (System Status shows Hardware Version: 09-xx). The other hardware version has no this problem.
Translation: New HW introduced due to component shortages introduced a skew between ADC's that is remedied with this new FW.
Hello,
Thank you for the news !
My SDS1104X-E is 09-06 Hardware Version so I have just downloaded the file, then will upgrade mine
(but I have not really understood the "skew between ADC" , have I different type of ADC in my model because of the shortages? )
Edit: Upgrade OK, but the scope has deleted all my settings, so I have reloaded them from the "default" Button where I have saved them (and have also a copy on a little 4GB USB Stick)
I have done a recalibration after all that, without anything on the input
This must not happen !
Please list each of the settings types deleted and I'll report this to Siglent.
Hi, I just found this big thread.
I wonder if the hobbyist upgrade can be done after the V6.1.37R9 firmware, and where explains the steps to upgrade it.
Thank you.
Thank you.Thought I'd let you search for a day or 2 only to find your answer was currently on P2 of the TE board:
https://www.eevblog.com/forum/testgear/unlocking-siglent-sds1104x-e-step-by-step/
Thank you so much. I still can't find it. Maybe a link?
I guess this kind of thread should keep updated the OP with the necessary info or at least an index to the relevant Replies.
I asked where are the steps because I found several times in other threads that the first posts were outdated and just close to the last post I found the correct solution.
I never did update my firmware's yet, on any of my Siglent gear.
I have 2-3 of the default probes, that must have a break in them somewhere, and sometimes the cables lose gnd, and other times just get weird in some positions.
So how hard is it to take them apart, and fix the crack or whatever, and fix it ? I just remembered they are not just ordinary coax.
But if I don't care about cutting 1 open , are they fairly easy to fix, like with solder, and glue, electric tape, maybe even tinfoil
Oooh, OS version 8.3. Anyone know what features this has over the previous version? I can't see any reference to minor OS revisions on the Siglent website.
Is anyone using the new counter function? It appears not to work the way I would expect--it gives you the option of selecting any active channel--and changes the color of the 'Frequency' annunciation to match, but won't actually indicate anything unless the trigger source is that channel. I'm not sure how that is a helpful feature...
I have an 1104-XE with the latest everything I believe. On the 4 channels 2-3-4 all are within 1 mV of zero with the input shorted gain max. However Ch1 is at +3 mV. I did a self cal and its the same afterwards as before. Is there an adjustment or something I need to do? Is this within tolerance? Its not very important, however only one channel seems to be afflicted so there may be more to this.
I did not realize the channel was set for a 10X probe when I sent the original note.
I followed the suggested process which cleaned up the offsets (at least down the the noise level). Picture attached. I'm not sure what had left the offset but its essentially gone. Ch 2 has a little offset but not enough to be concerned.
