0 Members and 34 Guests are viewing this topic.
Is it possible to calibrate the internal time base or frequency display? my SDS 1104X-E always shows only 9.99995 MHz at an exact frequency (10MHz GPSDO)!
QuoteIs it possible to calibrate the internal time base or frequency display? my SDS 1104X-E always shows only 9.99995 MHz at an exact frequency (10MHz GPSDO)!Same here, on the sds2000x+.I think it´s a "digit problem", which means it´s not a real problem but a "natural" matter of fact.
Hi thereCan anyone explain the meaning of the beep when starting the SDS 1104X-E?My device sometimes beeps twice at startup? (Firmware version: V6.1.35R2)
Quote from: SHF on March 07, 2020, 09:32:22 pmHi thereCan anyone explain the meaning of the beep when starting the SDS 1104X-E?My device sometimes beeps twice at startup? (Firmware version: V6.1.35R2)It's like a POST test but if you don't like it in Utilities you can turn the sound OFF. Use Default and it will be back unless you make your personal Default settings and save then using the Set to Default feature in the Save/Recall menu.
New Firmware https://int.siglent.com/download/firmwares/?ProId=12 Version: V6.1.35R2
I'd like to understand how the internal frequency counter works. I measured an SPI clock of 10MHz. The measurements show a perfect frequency value but the frequency counter shows <10Hz. Why? What am I missing?
