Strange.
I tried again and my .bmp files are around 750 KByte.
In .jpg format they are 120kByte. Both formats are 800 x 480.
I try to send the 3 screenshots in .jpg format.
I hope things are going well now
I see: now the images are oke.
For completeness I append my original questions
I have made some I2C experiments with my nice SDS 1104X-E scope (software version 6.1.33) and have a question about the record length of I2C data.
I send I2C data from an Arduino Pro Mini to a MPC4725 12 bit DAC on slave address 0x64 followed by the update command byte 0x40. After each update 0x40 follow 2 bytes DAC data from 0x00/0x00 to 0x26/0x26 (total 117 bytes, from 0Volt to approx. 0.5V) .
If I decode this data on my SDS 1104X-E I can see only the first 66 bytes in the Long Data window, please see screenshot_1.
Question: is 66 the maximum I2C record length?
Another I2C question I have is about the data in the bottom (blue) data line, please see screenshot_2. Here the time base for the same data is 200usec/div.
As you can see the bottom data line is a fragment of the long data window. If I turn the Y-position to the left to see more data the complete data suddenly disappear, see screenshot_3.
Is this a bug in the scope software?
Many thanks in advance!
