Author Topic: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes  (Read 678667 times)
0 Members and 17 Guests are viewing this topic.
Online tv84
  • Country: pt
Re: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes
« Reply #1425 on: July 20, 2019, 09:48:15 pm »
Each interface should have it's own ip-address so who would return should not be a problem. How ever I think implementing "services" on multiple interfaces is not trivial. So I can imagine only one (primary) interface get the services behind them. Maybe the first that gets an IP address, hence the difference between dhcp/static. But thats guessing, with a perfect implementation both interfaces could be used.
However I even experienced issues using only ethernet, like a SCPI session that gets broken, when using the web service simultaneously. (Solution: close the web-page)
As you say, all depends on the services/app running in the scope. I don't believe Siglent would go to the effort of devising such a thing just because someone wants to use both interfaces in the same network.
Offline HendriXML
    • KiCad-BOM-reporter
« Reply #1426 on: July 20, 2019, 10:07:39 pm »
But it would be nice the UI would give insight in what interface is active, or let the user select one.  :-+
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
Offline tautech
« Reply #1427 on: July 20, 2019, 10:58:59 pm »
It does and always has.
Bottom right corner of the display shows when LAN or WiFi is selected and if they each are active.
The WiFi signal strength indicator will be grey'ed out when out of range and the LAN indicator shows a small red x when not connected.
Offline HendriXML
« Reply #1428 on: July 20, 2019, 11:26:57 pm »
I don't have the adapter and I won't get one either. Happy with ethernet. But I can imagine it doesn't show which of the interface actually works. (Assuming only one can)
Having an extra indication and a guide in the manual to solve the above issue would be  :-+
Offline MikeLud
« Reply #1429 on: July 20, 2019, 11:29:53 pm »
I think I figured out what my issue is. I have a router and access point using the same SSID and the scope does not like seeing two of the same SSID. All of my other wireless devices on the network has no issues with two of the same SSID. If I power off the access point the scope has no issues.
To All Thanks,
Mike
Offline tautech
« Reply #1430 on: July 20, 2019, 11:41:09 pm »
It shows one or the other, only the active one (one selected) not both.
Yep the manual should show the WiFi indicator as a example for users and I'll ask Siglent to include this in their next manual update.
This screenshot shows the WiFi ON but the signal indication is greyed out due to being out of range from my WiFi connection. (in another building)
Seen next to the USB drive indication.
Offline HendriXML
« Reply #1431 on: July 20, 2019, 11:43:58 pm »
Good that you found the issue  :-+
Also  :-+ for the good indication of what's active.
« Last Edit: July 20, 2019, 11:48:04 pm by HendriXML »
Offline tautech
« Reply #1432 on: July 20, 2019, 11:49:14 pm »
Well when I looked back it had linked.
Offline MikeLud
« Reply #1433 on: July 21, 2019, 05:33:58 pm »
To All Thanks,
Mike
I was able to get the scope to work with both the router and access point power up and using the same SSID. The original settings had the access point using channel 4 (the weaker signal for the scope) and the router using channel 11 (the stronger signal for the scope). To get the scope working I changed the channel setting for the router to channel 1 (so the scope uses this channel first) and the access point to channel 6.
Mike
Offline MikeLud
« Reply #1434 on: July 21, 2019, 06:00:33 pm »
While trouble shooting my wireless connection issue I found something interesting. If you have the scope set for a wireless connection and using a static IP it also gets a DHCP IP. See photos below, scope is set to a static IP of 192.168.1.212 also the scope is getting a DHCP IP of 192.168.1.168.
791280-0
791286-1
791262-2
791268-3
791274-4
« Last Edit: July 21, 2019, 06:16:18 pm by MikeLud »
Online tv84
  • Country: pt
« Reply #1435 on: July 21, 2019, 06:57:36 pm »
 :scared:
Why do you think IP 192.168.1.168 is scope?
Offline MikeLud
« Reply #1436 on: July 21, 2019, 07:04:24 pm »
:scared:
Look at the IP at the top of the photo and in the LAN Configuration.
« Last Edit: July 21, 2019, 07:07:01 pm by MikeLud »
Online tv84
  • Country: pt
« Reply #1437 on: July 21, 2019, 07:15:54 pm »
But you are using ETH and WIFI, right?
Offline tubularnut
« Reply #1438 on: July 21, 2019, 07:24:45 pm »
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
(Attachment Link)
That page is for the LAN config, which is the ethernet cable. the 168 address will be for your WiFi, therefore 2 addresses.
Offline MikeLud
« Reply #1439 on: July 21, 2019, 07:25:56 pm »
No, just WiFi, the Ethernet is not connected
Offline Dundarave
« Reply #1440 on: July 21, 2019, 07:27:00 pm »
When I was playing around checking the scope’s WiFi vs Ethernet capabilities, I seem to recall discovering that you could only ever have one or the other active, and I had to use different IP addresses for each.
This may have changed with the latest firmware, but worth checking out.
The remote response on the browser was always so much better over Ethernet, I only rarely use WiFi.
Offline tubularnut
« Reply #1441 on: July 21, 2019, 07:27:20 pm »
Hmm, indeed very odd.  :-//
Offline tautech
« Reply #1442 on: July 21, 2019, 07:28:06 pm »
Yep, cause you have static settings for each.
Offline MikeLud
« Reply #1443 on: July 21, 2019, 07:35:32 pm »
I have only the WiFi enabled set to a static IP of 192.168.1.212 and no Ethernet cable connected. With this setup I can ping both IP 192.168.1.212 and 192.168.1.168 also I can navigate to both IP's with a Web Browser.
Online tv84
  • Country: pt
« Reply #1444 on: July 21, 2019, 07:39:48 pm »
Based on your last info, my only conclusion is that the scope must be routing the IP packets between both IP stacks internally.
If you get me a 3rd IP than I'll be amazed!!!  :-DD
Offline tautech
« Reply #1445 on: July 21, 2019, 07:42:59 pm »
That just might be possible too !
2 saved settings then turn DHCP ON to get a 3rd auto negotiated IP but don't Save it.  :P
Offline MikeLud
« Reply #1446 on: July 21, 2019, 07:53:25 pm »
After thinking about it maybe the USB wireless adapter is getting the DHCP IP 192.168.1.168 and the scope is using the static IP of 192.168.1.212. Also the USB wireless adapter has its own MAC address different from the scope.
Online tv84
  • Country: pt
« Reply #1447 on: July 21, 2019, 07:57:23 pm »
I thought you already knew that!  The question is you accessing both IPs with just one connection.  The scope behaves as having an internal network switch, as you configured both interfaces in the same network. Nice.
Offline tautech
« Reply #1448 on: July 21, 2019, 08:00:33 pm »
Nope, it can only use one or the other not both at once.
Online tv84
  • Country: pt
« Reply #1449 on: July 21, 2019, 08:12:05 pm »
Yes, but through one interface you can "see" the other...
Which poses a problem: if you have all the network configured with DHCP, connected to the scope only via WIFI, but you have a static IP in  the scope's ETH interface (as seems to be the case), one can have a problems of collision between IPs. Must choose DHCP pool with care or have both scope's interfaces configured with DHCP.
