This happens to me every time, ive even tried hot spotting my phone ![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
OK I think I have this WiFi stuff sorted.
1. Your IP settings must be known and correctly set and SAVED; IP, Subnet and Gateway.
2. Or, DCHP can be ON and let router provide the IP info and then SAVE it.
3. If there is still difficulty in getting a wireless connection revert to a wired LAN so a connection can be obtained so in the webrowser Welcome page LAN settings that are elsewhere not accessible can be changed for trouble free and instant connection.
In the webrowser LAN settings you can have DCHP ON or a static IP configuration that must be set in the Modify Settings page. Just be sure to double check webserver IP settings match the scope IP settings.
For some stupid reason I had a part of an IP in the Modify Settings page and it caused all sorts of problems and unreliability of WiFi.
Now it's rock solid.
![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
About the PSK, oh yes WPA2.
![Embarrassed :-[](https://www.eevblog.com/forum/Smileys/default/embarrassed.gif)
