Can someone please do a real test on the decoder functionality in the oscilloscope?
Really debug an SPI signal or a CAN bus signal, and use all 4 channels for the decoding.
There's 2 tools that can help here;
The Serial Trigger suite and the Search function.
Both have a list of parameters that can be selected and values user defined.
With Search you can have it just flag an event or Stop sweeps by transferring the settings to the Trigger.
Search settings are mainly edge, pulse, interval and runt, each with a range of user definable parameters.
Simple decoding can be performed without use of the Decoding Trigger suite and there's a decent list of tools in the suite if needed.
From the datasheet:
I2C
Start, Stop, Restart, No Ack, EEPROM, 7 bits Address & Data, 10 bits Address & Data, Data Length
SPI
Data
UART/RS232
Start, Stop, Data, Parity Error
CAN
All, Remote, ID, ID + Data, Error
LIN
Break, Frame ID, ID+Data, Error
Many/most parameters are definable.
