Author Topic: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes  (Read 664619 times)
0 Members and 16 Guests are viewing this topic.
Re: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes
« Reply #2550 on: May 28, 2024, 06:44:43 pm »
My SDS1204X-E is running SW 6.1.37R2, UBoot-OS 7.1, FPGA version 2021-07-12, HW version is 01-03. It has all the options (permanent licenses).
Anyone had issues upgrading to the newer versions?
No.
But you have some work to do to get to the latest versions, FW and OS.
Do some study:
https://int.siglent.com/download/firmwares/?ProId=12
Offline sdriussi
« Reply #2551 on: May 31, 2024, 02:20:32 pm »
Hello,
I'm trying to measure voltage with SCPI command in python from a capture with my SDS1204E-E but I can't. All commands that I have found are not recognized. This post is the only one where I got commands that work but still no succes to measure.
I wrote a python script that return a value or an error on timeout for severals commands. Here is the output (command answer/timeout):
*IDN? Siglent Technologies,SDS1204X-E,SDSMMFCC5R0424,8.3.6.1.37R10
SYST:DATE? 20240531
SYST:TIME? 150038
C1:VDIV? 2.0
C2:VDIV? 1.0
C3:VDIV? 0.5
C4:VDIV? 1.0
C1:TRLV? 3.0
C1:BASICWAVE? C1:BSWV WVTP,SINE,FRQ,1000HZ,PERI,0.001S,AMP,4V,AMPVRMS,1.414Vrms,OFST,0V,HLEV,2V,LLEV,-2V,PHSE,0
C1:CURSOR_SET? VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
C1:CURSOR_VALUE? VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
CMPA VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
CURR_MEASURE_STAT VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
CMR? 0
CONET? 10,11,13,220
COMM_NET? 10,11,13,220
CRMS? MANUAL
CURSOR_MEASURE? MANUAL
CRSC? VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
CURSOR_MSOURCE? VI_ERROR_TMO (-1073807339): Timeout expired before operation completed.
CRTY? X
CURSOR_TYPE? X
How to do gate measurement ?
I have attached a screen capture done with the SCDP command
« Last Edit: May 31, 2024, 02:24:31 pm by sdriussi »
Offline Fenstergucker
  • Country: at
    • Private Website
« Reply #2552 on: May 31, 2024, 03:22:48 pm »
In the screen shot the source for the cursors is Channel 3, in your script you use Channel 1. Perhaps this is the error.
Peter
Offline sdriussi
« Reply #2553 on: May 31, 2024, 04:08:42 pm »
I have changed C1 to C2 then C3 and C4, same issues. To the command C1:WF? I got 00E+002200003
What is the format of this return ?
Stéphane
  • Country: at
    • Private Website
« Reply #2554 on: May 31, 2024, 04:21:41 pm »
Stéphane
This is in the programming manual, this should be the current one, page 263:
https://int.siglent.com/u_file/document/SDS1000%20Series&SDS2000X&SDS2000X-E_ProgrammingGuide_PG01-E02D.pdf
Peter
The following users thanked this post: sdriussi
Offline ironcurtain
  • Country: aq
« Reply #2555 on: May 31, 2024, 05:24:01 pm »
No.
Do some study:
No problems after upgrading. Did not push V3 OS though.
Updates are trivial, I was only interested in side effects for users that have hacked functions. I think it is very unlikely Siglent will/can break the keying, since they would need to reissue licenses to all their legitimate users.
They also don't care, the only people using keygen'd licenses are hobbyists.
"If you are going to fail, at least do so spectacularly."
Kurtz: [intercepted radio message] I watched a snail crawl along the edge of a straight razor. That's my dream; that's my nightmare. Crawling, slithering, along the edge of a straight razor... and surviving. -- Apocalypse Now (1979)
« Reply #2556 on: May 31, 2024, 08:17:40 pm »
No.
Do some study:
This ^
In the many years and many updates for many models I don't recall ever losing a licence to an update process.
Install V3 OS with confidence.
One particularly useful feature it offers is NTP time to provide accurate capture timestamps.
Offline sdriussi
« Reply #2557 on: June 03, 2024, 08:06:19 am »
Peter
Thanks Peter, I'm able to get the trace. I will read the pdf guide to search if I can place cursors and get the voltage at their locations
« Reply #2558 on: June 28, 2024, 10:41:30 pm »
New firmware for 4ch SDS1000X-E models
Version: V6.1.37R17
9 MB
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1xx4X-E_V6.1.37R17_EN.zip
Release notes
1. Optimize Autosetup speed
2. Optimize SDS1104X-E bandwidth
3. Standard software functions of FG, LA and WIFI
The following users thanked this post: 807, JohanH, luciof, Wrenches of Death
Offline Calambres
    • Piso-Tones
« Last Edit: June 29, 2024, 07:25:56 am by Calambres »
Offline pope
« Reply #2560 on: June 29, 2024, 08:35:46 am »
Version: V6.1.37R17
9 MB
Release notes
What does "Optimize SDS1104X-E bandwidth" mean?
Offline 807
« Reply #2561 on: June 29, 2024, 09:43:17 am »
Not yet announced either here:
https://www.siglenteu.com/service-and-support/firmware-software/digital-oscilloscopes/#sds1000x-e-series
nor here:
https://siglentna.com/service-and-support/firmware-software/digital-oscilloscopes/#sds1000x-e-series
Tautech always ahead of them all... thanks mate!  :-+
Strange that it's not available to download from eu site, but it is mentioned in the release notes if you click on it.
Offline 807
« Reply #2562 on: June 29, 2024, 09:45:09 am »
Version: V6.1.37R17
9 MB
Release notes
I was wondering the same thing.
Offline 807
« Reply #2564 on: June 29, 2024, 10:20:35 am »
nor here:
Oh yes they are, scroll down some.  ;)
That's a strange way of listing them. Why not all in one list? A lot of the releases are on both lists, but R10 was on the first list but not the second & R17 is on the second list, but not the first. Why split them up like that?
Unlike the na site, the eu site has the release notes for R17 in both lists, even though it doesn't appear in the first list.
« Reply #2565 on: June 29, 2024, 10:31:06 am »
nor here:
Yeah I know, not my problem.  ;)
The following users thanked this post: Calambres
Offline Calambres
    • Piso-Tones
« Reply #2566 on: June 29, 2024, 02:47:03 pm »
Yes, you're right   ^-^ but indeed a weird way to list the different FW versions...
BTW: what is FG & LA?
Offline Dave Wise
« Reply #2567 on: June 29, 2024, 03:03:22 pm »
I'd guess Function Generator and Logic Analyzer.  As in, make the scope talk to them.
Offline TomKatt
« Reply #2568 on: June 29, 2024, 09:19:24 pm »
FWIW - Siglent also released new FW for the SDS800X HD series that had this same verbiage and I noticed that after installing it the LA and FG options no longer appear in the licenses screen, as if they are now automatically permanently enabled.
I don’t have access to my SDS1104X-E but I’d guess this is also the case here.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PIC
The following users thanked this post: atroz
« Reply #2569 on: June 30, 2024, 08:50:52 am »
Just checked mine, no sign of any options menu now.  :-//
Though I do have some (not Siglent) special tools to reset options to zero/trial....wonder if anything appears if I do ?......
Offline atroz
« Reply #2570 on: June 30, 2024, 04:01:38 pm »
Version: V6.1.37R17
9 MB
Release notes
Anybody figure this out yet?    They really could improve their release notes, even going to so far as doubling their word budget could help.   ???
Offline TomKatt
« Reply #2571 on: July 01, 2024, 10:46:07 am »
Version: V6.1.37R17
9 MB
Release notes
Has anyone figured out what the 'Optimize SDS1104X-E Bandwidth' means?
I find it interesting that although the FW release is for the 4 channel SDS1004X-E series, Siglent mentions the SDS1104X-E model specifically.
Offline robert.rozee
« Reply #2572 on: July 01, 2024, 12:09:16 pm »
has anyone verified that:
1. this latest update does not affect an SDS1104X-E (100MHz) that has previously been upgraded to an SDS1204X-E (200MHz) using a user-installed option key,
2. when applied to a 'stock' SDS1104X-E (100MHz), if the update upgrades the bandwidth to be the same as that of an SDS1204X-E (200MHz) - ie, creating a new variant, a 200MHz scope that still identifies itself as an SDS1104X-E.
cheers,
rob   :-)
Offline TomKatt
« Reply #2573 on: July 01, 2024, 12:16:42 pm »
cheers,
rob   :-)
Should be easy enough to test - just take an 'upgraded' scope and revert it back to 100MHz BW, then apply FW update and see what is reported.  I may try this later this afternoon if nobody else has done it by then.
Whatever this comment means, I doubt Siglent just turned all their 1104 models into 1204 models...
The following users thanked this post: Performa01
Online Zoli
  • Grumpy old men
« Reply #2574 on: July 01, 2024, 05:14:08 pm »
Considering that this update adds all the options as standard, I don't see why the bandwidth option would be different.
