Hey,
i got a problem with my sds1104x-e, it wont recognize any usb drives anymore.
(i did that sds1204x-e firmware thing back in the day, usb worked after that no problems. it worked just 2 months ago when i last used it, havent done anything but maybe measuring one or two things since.)
when i insert a usb drive, it says "USB flash drive removed" hitting the screenshot button says, no usb flash drive detected.
i tried with 5 different drives ranging from 2 to 64gb, all FS from exFAT over FAT32 to NTFS. USB drives, usb card readers with sd cards in it. drives that definately worked before.
i hit (in windows) "format to device defaults" to reset block sizes, i tried with volume name and without..
i tried the back and front usb port, i hit default to reset settings, i disconnected power for a while, i tried rebooting..
i tried via the save/recall menu, via the system menu (firmware, configuration) also nothing.
i cant get it to work for some reason.
anyone got an idea?
EDIT:
i have found 4gb sd card that works! no idea why my 2gb stick with fat32 didnt, nor the sticks that worked before.
updated firmware to 6.1.35R2 but still usb drive cannot be detected. i also tried formatting it on another computer and from within a virtual box running kali.
