2. Contrary to popular belief, it is possible to disassemble the switches and clean them manually. It involves removing components behind the switches, blocking them from sliding backwards. Then you have to put pressure on the switch shaft downward, so it can squeeze out the back side. Each switch has 4 metal springs in it, which can easily be cleaned using an ultrasonic cleaner and alcohol. The inside of the switch (which just consists of two arrays of vertical pins) can also easily be cleaned thanks to the fact that a Q-Tip cotton swab covered with alcohol is exactly the same size as the channel, so it fits in there, cleans perfectly, and doesn't leave any cotton behind.
technogeeky, that's a good find. Do you have any pictures to post showing the disassembly process?
No, but I actually need to do one switch again: one of two of my meters came with a busted power on/off switch, solved (by them) by soldering pairs of pins together for that switch.
I replaced the switch with one from a dirt cheap 179, but there is some subtle difference causing the switch to block the locking of [ volts , amps, ohms ]. So I'll document the process.
As for the calibration thing, yeah. As someone here has said, there are two kinds of failures I'm aware of regarding the switches:
1) Them being broken (like when the toggle metal pin digs out of whatever that thing that's in the top of the button shafts, like the power button; the mode select buttons). The springs being broken and jammed. Whatever. The important thing is, these can do anything from totally ruin the usability of the device all the way to having no effect at all. But I class these kind of switch breaking that will not effect calibration (e.g. they do not show up as a difference in resistance or if they do, it turns out not to matter).
2) [Note: I am an amateur, but...] In nearly every case where a corrosion-induced change in resistance of a switch contact
can make a difference, it seems like it actually
does make a difference. To see this, you can just consider all combinations of switches. But first, you simplify:
- You can ignore all of the range switches in the Volts and Ohms ranges; here they are just selectors fed to the mcu.
- The power switch either works, or it doesn't. In any case, resistances involved can get absorbed into the corrective abilities of the power supplies. So we can ignore these..
However, in nearly every remaining case, the switch contact itself somewhere
in the signal path:
- In amps mode, the range switches will be combined into the shunt resistance itself, in series-parallel.
- The Amps switch contacts themselves are also in the signal path, for the same reason.
- Every two-position triplet of the AC/DC switch is in the signal path (and even the guarded path)
- The Volts, Ohms, and Amps switches all have places where one of their contacts is involved in a crucial circuit: connecting the 2V ref to the circuit, connecting signal ground to the circuit, connecting in with the -6.4v ref usage on the 2nd page of the schematic (ohms mode), even the ohms switch triplet [7 8 9] which seems like it can't matter (just a 5v rail). But even that switch contact's resistance is thrown in among 1500 ohms to ground. And then it gets sent to every FET driver opamp on the negative rail.
So unless all of this is totally a wrong way to look at this circuit, and for some reason I don't understand none of these things can matter... then as long as I had a meter which gave calibrated results when it was obviously working, but had intermittent errors due to switch problems of type one... I'll take the problems of type 1, and keep the (probably) calibrated meter. I can't afford calibration, and for the reasons that everyone has (very correctly) harped on, it is very risky working around the many high-impedance sections.
So that is essentially the argument for living with some types of switch problems. It's not perfect, and if I could afford actual calibration, it would be invalid reasoning I suppose.
There are also ton of selected parts in this meter, and while I have guessed at the selection reasons, I don't know any of them for sure. But it seems to me like there is some real FET greybeard work going on. And even some pretty clever selected BJT uses too.
