Now, after the case is opened, the power supply starts and the display shows the menu. The output voltage and current can be adjusted and are available correctly. It has a good toroidal transformer and is very good in design. One thing that was noticeable was that the fan ran at full speed after it was turned on with closed housing. The connector and cables from the fan are very close to the upper part of the housing. It is possible that one of the cables to the fan caused a short circuit with the upper part of the case. However, the cables to the fan look fine. I can't find any loose contacts on the circuit board or the connectors, the power supply runs without problems. I was able to buy the power supply with 70% discount. I think it was a good deal
