Clean up another corner, and apply wax to it, and use it to make a mould of that corner. Then use that mould, placed on the broken section, and use 2 part metal loaded epoxy to make a filler piece. Then after the epoxy is cured sand down till it matches, and spray paint with silver paint the whole bezel, so that it looks like a single part, the paint covering the damaged section.
