I'm after a AWG and a LAB PSU now, and of course considering Siglent, if you know a distributor with reasonable international shipments let me know!
JS
Several but it's very bad form to sell into another authorized distributors patch, period.
Good luck should you need warranty or specialized support from the Asian mum and dad backstreet shops, just good luck !
In my experience a local distributor can be unhelpful as well. It is a bit of a hit & miss and you don't know until it is too late. Usually I use google with the company name and the world 'problem' to see if a shop is any good or not before buying. Last year I bought something from Italy instead of the local NL distributor because the NL distributor seemes to have very bad customer services (sell broken / DOA items and then let customers wait weeks or months for repairs).
There's the answer I'd gave you, except electro-tools failed to answer my mails so I didn't even considered them. I wouldn't trust a seller who doesn't reply to quotes request to have a good support later. I totally forgotten about them.
Temtec did answered my mail quickly but they weren't importing any new products, just selling whatever they had left. I remember a 3458A for $5k which as you can imagine is a great deal here but I'm not in the market for that right now, but it catch my eye.
Sorry, but buying here makes no sense, support isn't great and prices either, this isn't just for your brand, don't take it personally, but for me, rigging up the lab for myself to be able to do what I know to do best I can't justify it. A bigger company, which needs someone to call and blame if something doesn't work, and have some benefits from buying locally, a university which needs to buy locally and doesn't have a choice, and a few other examples, will work with them, but for individuals setting up persona labs to be able to work I don't think so.
About FFT length, as I had said many times, I pick the data from the PC and run the processing there, I can run a FFT with the full memory depth, so for me being able to capture 24M points with 1GSa/s with some advanced trigger options is the most important feature. I wouldn't go with cheaper with low memory depth, but more expensive with more processing power wouldn't make a big difference for me. Math function limitations are in all the scopes and a bit more in some particular case doesn't make or brake the deal for me. The refresh sending the data to the PC won't be as fast but I can live with that, the times for me catching a rare event aren't that often. Once I had a fast, once in a few month event but I wouldn't trust the Siglent to catch it either, troubleshooting that wasn't easy... Also, 200kwf/s using deep memory isn't a thing anyway.
I wouldn't even bother in FW updates being easier or harder, is something you do once every few moth at most and be done with it. The key building blocks, as front end, ADC, etc. does bother me, the frond end is a win for Siglent as can go to a lower range better, you do have two ADCs but the same specs as the one in the Rigol, so for one channel are the same, where I would want to characterize a signal. I use as many channels as I have while debugging or troubleshooting but there usually I don't use the ADC to it's full spec. One strong point I see in the Rigol is the 24M for a single channel, I understand the Siglent goes up to 14M in a single channel, and in two channels they are closer 12M against 14M. Again, in this regard, to go to the PC, the Rigol wins. There are so many factors to consider, there is no a clear winner considering the price difference. Siglent is a more modern option with a lot of wins, even more as stand alone.
Before someone start to attack me why didn't I went with a PC based one to start with, I do use a lot of functionality while using as stand alone, but not while pushing it to the limits. The Rigol makes a great fit for me so far, some people won't be so happy going to the PC and want everything in the one device.
JS
