Author Topic: Anyone have a BNC Connector for a HP5460XB Series scope.  (Read 1431 times)
Offline scopemanTopic starter
« on: March 20, 2022, 05:53:05 pm »
I have a HP54602B where one of the BNC connectors has been damaged beyond repair. Does anyone have one of these for the B series from
a scrap PCB assembly? The A version uses different BNC connectors that are part of a cast assembly so they sadly will not work. The B series
has a guide pin on the rear of the connector and it is secured with a T8 metric thread screw.
Thanks,
Sam
W3OHM
W3OHM
