I searched the forums but did not find anything appeared relevant...
I 'upgraded' my Siglent SDS1104X-E to the 200 Mhz version using the serial generator code. No issues and it seems to work fine and now identifies itself as the SDS1204X-E model, which makes sense. I see there is a firmware update available for the SDS1104X-E model (and the 1102 + 1202), but curiously there does not seem to be any release (or past history) at all for 4 channel 200 Mhz SDS1204X-E models?
Has anyone been in this situation that can suggest which firmware file version I should use? I'm assuming that the SDS1104X-E firmware is the one to use in my case. If the update complains about incorrect model, I guess I could 'downgrade' my scope to it's original configuration, apply the fw update and then 're-upgrade' it again, since it's just option serial codes.
Any information would be appreciated - thanks!
Edit - list of FW files available. No 1204 version at all? Strange.
