Problem resolved.
It turned out to be a slightly bent probe tip not allowing the hook to snap on properly.
Took off the hook, straightened the tip, put the hook back on and ..
Everything is fine. Thanks nctnico, your post started me on the road to figuring it out. I had been monitoring the filter output with another scope and the signal coming out should have been fine, and sure enough it was.
