Both have 2 1GSa/s ADCs so that it has 1GSa/s for one or two channels, 500MSa/s for 3 or 4. So at 200MHz and 4 channels it has 2.5 samples per period, which "just" meets the Nyquist criteria, I suppose.
Do competing products do better??
Not really because the input circuitry isn't bandwidth limited. It has a -3dB point around 300Mhz and there can still be plenty of signal above that.
Quote from: Fungus on August 25, 2019, 05:40:57 pmNot really because the input circuitry isn't bandwidth limited. It has a -3dB point around 300Mhz and there can still be plenty of signal above that.All very true, but I was referring only to his question about the sample rate meeting the criteria.
Hello. Could not find fast answer. Does Siglent SDS1104X-E have 1 GSa/s per channel? If so it's not very good, barely covers Nyquist criterion if all 4 channels are used. Same question about SDS1204X-E. Thanks in advance.
