I had to take this exact choice a few years ago, and the two main candidates were the Siglent SPD3303X-E and the Rigol DP832.
I have limited bench space, and the Rigol is deep and heavy! The Siglent is significantly less deep and is more practical in terms of physical size and weight. The Siglent also has a bigger screen. But in the end, I ended up buying the Rigol, and here's why:
* The Rigol is a bit more expensive but is "hackable" to get 1mV/1mA resolution. You can also turn it into a DP832A quite easily.
* Independent control of the third channel
* Standard spacing between the banana connectors
* At the time the Siglent did not display the set voltage and set current on the screen. This seems to be fixed now though.
The Rigol has a keypad!!*
The Rigol has dedicated V, mV, A and mA keys!!The last one can't be said enough. When you have 1mV/1mA resolution it's just slow and painful to use the wheel and arrow keys to set the voltage and current. How do I know? It's absolutely possible to use the arrow keys on the Rigol too. But why would I do this when I have a keypad and dedicated unit keys? A keypad is multiple times faster, especially if you're switching to an odd setting where you need to twist and tweak a lot to get there. And with a keypad you don't need to turn off your output, it will simply jump to the new set voltage.
Want to set your voltage to 16.67V at 0.1A? You can just start to type, no matter where you are on the screen or what the previous voltage/current was:
[1] [6] [.] [6] [7] [V]
[.] [1] [A]
On the Siglent this would be a few dozen twists and presses to get the same setting.
TBH I think Tautech's argumentation against having a keypad is just silly. I'm sure he would call it a nice and useful feature if it were present on the Siglent. Having a keypad on an instrument like this is a must. I think everyone agrees on this.
And BTW, I'm no Rigol fanboy. I just got myself an SDG2042X signal generator (with a keypad), and it's just a fantastic piece of gear But I wouldn't have bought it if it didn't have a keypad
