Hi All,
This is my first post of EEVblog, and I thank everybody for the real work they have done to make this possible.
I have only been shopping here, combined all and made some minor changes.
I've been struggeling with connecting FY6900 SWVersion 1.5.5.1.3 (delivered nov 2023) to my SDS1104X-E SWVersion 6.1.37R10 (delivered may 2024):
The result of my struggle:
I use the espBode-master date 08-12-2020
I had to add ESP_Telnet to my library
I use in the Arduino IDE: the library ESP8266 by ESP8266 community version 2.7.4
In SDS1104X-E Utility--page2/4--I/O--IP Set-- DHCP Disabled
I have discovered that the SDS1104X-E only remembers the first 9 charachters of the WiFi PSK after power down!
I use the TL-WN725N WiFi adapter from TP-LINK for my SDA1104X-E, the WiFi signal must be strong, otherwise you have no steady connection!
I use a 3V3 regulator in my adapter between the ESP01S and FY6900. The uP in de FY6900 has a 3V3 interface. The CH340 has also a 3V3 interface.
In my FY6900 the resistors between CH340 and TTL connector and uP are:
R30 and R32 are 300 Ohm between TTL and uP, R19 and R20 are 2k between CH340 an uP, no need to change!
In esp_config.h change:
#define WIFI_MODE_AP
//#define WIFI_MODE_CLIENT
/* WiFi credentials */
#define WIFI_SSID "wlan_ssid"
#define WIFI_PSK "wlan_key"
/* Comment this for DHCP. However you'll need to obtain IP somehow. */
#define STATIC_IP
Into
//#define WIFI_MODE_AP
#define WIFI_SSID "Your_wlan_ssid"
#define WIFI_PSK "Your_wlan_key"// no more than 9 charachters, otherwise you have to change your password of your network first
//#define STATIC_IP
The compilerfault:
esp_network.cpp:222:1: error: control reaches end of non-void function [-Werror=return-type]
222 | }
I inserted quick and dirty an extra line with return 0; in the file esp_network.cpp at line 222, and had no problems afterwards.
Original code: in file "esp_network.cpp" at end of function: "uint8_t handleVxi11(uint8_t *packet, WiFiClient client)"
client.write((uint8_t*)&write_response, sizeof(rcpresp_devReadWrite));
return 0;
break;
Inserted line with return 0; at line 222:
return 0;
break;
return 0;
The problem of frequency adjustment in the new FY6900 60MHz mentioned by bigpriap a few posts back:
I have changed in esp_fy6900.cpp line 64 and 73 from
snprintf(command, 19, "WMF%08lu000000\n", frequency);
Into
snprintf(command, 19, "WMF%08lu\n", frequency);
In order to see the IP adress of your ESP01S you have to remove the slashes on line 56 of esp_config.h
//#define DEBUG_PRINTS
becomes:
Compile and write to the ESP01S
Start the EPS01S an look at the Serial monitor.
After reading and writing down the IP adress (to be used in the bode plot-menu of the SDS1104X-E), put the slashes back:
and compile and write to the ESP01S and the ESP01S is ready to be used.
Ik hope that this information helps others to get it working.
