Last night I found a Weller WTCPS PU120 with what looks like a TC210 iron on the side of the road. It cleaned up nicely and the Magnastat switch seems to work because you can hear and feel it switch on and off while keeping the temperature constant.
The rather pointy conical tip looks like it's original to the unit so it's kind of crusty looking. It would be nicer if it wasn't so pointy too.
Question: What's the best way to measure the temperature of the tip?
I held my cheap hardware store K type thermocouple to the tip and it never gets over 270C. Then I melted a blob of solder onto a piece of fiberglassed plywood, held the iron in the tiny blob and stuck the thermocouple in the molten solder. Using this method it measures 340C.
Is this a valid method for measuring the temperature of a soldering iron?
ALSO: What's the best place to find tips for this blue nameless white silicone corded 24V 42Watt Weller iron?
According to the TC201 documentation changing the tip changes the temperature somehow.
