Recently I did a firmware update on my 1052 which then upgraded the model to a 1202(?). Not in front of the DSO right now. Not happy with it has it causes the DSO to run slow eg changing voltage level from say 1v/DIV to 10v/DIV can take up to a minute for anything to happen. Is it possible to back pedal back to the original firmware?
Adrian
1202(?) ??
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Never been such a model.
Where did you source the firmware from ?
SDS1000DL+ firmware page:
https://int.siglent.com/download/firmwares/?ProId=42
I downloaded the firmware from that site. This is what happened after updating the firmware.
Adrian
A better picture
Adrian
WOW, a 200 MHz DL+ !
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
I'll drop tech support a line for you.
Thanks. Appreciated
Adrian
If you want to downgrade the BW, send me a pm.
All good thanks TV84. Now (hopefully) back to normal.
Should have asked the question about the firmware upgrade before I did it
Adrian
