Can you provide some more details about the SDS1kCML+ series?
Isn't the "CML" version part of an older series? At least they used to use these letters in some older products, which had much less memory, where C meant color if I am correct, M meant memory, and L something else, which I don't remember
Does the "+" also stand their for the LA option, or does the "+" there just stand for "restyled"?
SDS1102CML updated using 800x480 resolution TFT and added LAN connection is SDS11102CML+
It is fully explained in Siglent official web sides.
These updated models are:
SDS1052DL+ is 50 MHz, 2 CH, 500 MSa/s (Max.) , 32 Kpts, 7 inch (800*480)
SDS1072CML+ is 70MHz, 2 CH, 1 GSa/s (Max.) , 2 Mpts, 7 inch (800*480) (
NOT in EU)
SDS1102CML+ is 100 MHz, 2 CH, 1 GSa/s (Max.) , 2 Mpts, 7 inch (800*480)
SDS1152CML+ is 150 MHz, 2 CH, 1 GSa/s (Max.) , 2 Mpts, 7 inch (800*480)
(are upgraded in screen resolution and memory for recorder; Lan interface added, front panel refreshed)
New (+) is: 7”color TFT 8×16 800×480
Old was: 7”color TFT 8×18 480×234
Waveform storage: Old 20, New(+) 10
Record Memory: Old 6M, New (+) 7M
Interfaces:
Old:USB Host, USB Device (USBTMC), Pass / Fail
New (+) :USB Host, USB Device (USBTMC), LAN (VXI-11), Pass / Fail
Old SDS1000CML series: Discontinued.
Old SDS1000CNL discontinued exept old SDS1202CNL+ continue:
SDS1202CNL+ parameters, including display unchanged and still available (200MHz,
2GSa/s, 18k mem)
(this is exeption and this + have nothing to do with this new DL+/CML+ improvement. This CNL+ was old other improvement in older SDS1202CNL)
Some discontinued models still available and of course support and warranty is normal and continue normally.
