New Firmware for 1000X HD - 1.1.3.8
I did not find 1.1.3.6 even on Chinese site, maybe in new units from factory.
2024/06/14
1.1.3.8
1. Optimize UI, change "on/off" to "On/Off".
2. Solve the problem that some numbers from 200-223 cannot be entered in the first byte of the IP address.
3. Standard software functions of FG and LA.
2024/05/22
1.1.3.6
1. Solve the problem of trigger holdoff fails.
2. Solve the problem of CAN decoding causing crashes with a small probability. 3. Modify the kernel s olve the problem that scpi cannot be
used on a computer with keysight driver installed
4. Solve the problem of advanced trigger (Qualified, Nth
Edge, Delay, Setup/Hold) parameters are not recalled.
5. Solve the problem of delay trigger level setting error.
6. Solve the problem of when the edge is set to Alternating, trigger jitter will occur when entering the other trigger type.
7. Solve some known problems.
8. Optimize waveform capture rate.
9. Optimize self calibration speed.
10. Optimize UI.
