Author Topic: Siglent SDS1000X HD 12bit 2GSa/s Oscilloscope Unboxing & Test  (Read 108392 times)
Offline idolclubTopic starter
« on: January 05, 2024, 06:55:57 pm »
Siglent SDS1204X HD 10.1" 200MHz 12bit 2GSa/s Oscilloscope.
« Last Edit: January 05, 2024, 06:57:49 pm by idolclub »
The following users thanked this post: flano, Performa01, egonotto, NF6X, Mortymore, Serg65536, Triode71
Re: Siglent SDS1000X HD 12bit 2GSa/s Oscilloscope Unboxing & Test
« Reply #1 on: January 05, 2024, 07:05:14 pm »
SDS1204X HD System Info:
The following users thanked this post: Antonio90, Triode71
« Reply #2 on: January 05, 2024, 07:11:15 pm »
Noise floor:
« Last Edit: January 05, 2024, 07:22:28 pm by idolclub »
The following users thanked this post: egonotto, 2N3055, Antonio90, Triode71
« Reply #3 on: January 05, 2024, 07:13:20 pm »
Risetime on 10MHz Leo Bodnar :
« Last Edit: January 05, 2024, 07:38:34 pm by idolclub »
The following users thanked this post: egonotto, Triode71
Offline Martin72
  • Testfield Technician
« Reply #4 on: January 05, 2024, 08:04:21 pm »
Interesting, (grey-)import from china?
"Comparison is the end of happiness and the beginning of dissatisfaction."(Kierkegaard)
Offline tv84
  • Country: pt
« Reply #5 on: January 05, 2024, 09:39:44 pm »
They exist, after all!!!!!!!!!
What is the SCPI answer to?
:syst:board?
Online 2N3055
  • Country: hr
« Reply #6 on: January 05, 2024, 10:26:32 pm »
63µV AC RMS noise.. at 200MHz+ BW ..nice...
« Reply #7 on: January 05, 2024, 10:38:33 pm »
Yes.
The following users thanked this post: egonotto, Martin72
« Reply #8 on: January 05, 2024, 10:47:14 pm »
:syst:board?
UNNAMED_LIC-V1 & hackable.  ;D
The following users thanked this post: egonotto, tv84, Martin72, Triode71
Offline Martin72
« Reply #9 on: January 05, 2024, 11:34:56 pm »
Excellent... ;D
And, have you "liberated" the scope yet? 8)
Offline nervdg
  • Country: cn
« Reply #10 on: January 06, 2024, 01:23:52 am »
Teardown photos that someone posted on bilibili.
The following users thanked this post: egonotto, Mortymore, Antonio90, Triode71, Anthocyanina
Offline Martin72
« Reply #11 on: January 06, 2024, 01:34:30 am »
2 ADCs, aha...
Then they are not the same as in the 2000X HD.
« Reply #12 on: January 06, 2024, 01:38:04 am »
2 ADCs, aha...
Or told not to behave in the same way.
Earlier (pre dark scheme) shared similar HW…….
Offline Martin72
« Reply #13 on: January 06, 2024, 01:48:21 am »
Then you can only congratulate the future 1000X HD owners that they have a very good converter under the hood.
Are you still on vacation or can you already provide us with English data sheets?
« Reply #14 on: January 06, 2024, 02:08:55 am »
Signature says all. Home in 8 days.
« Reply #15 on: January 06, 2024, 09:49:10 am »
Excellent... ;D
Of course!! Already "FREE"......  ^-^
Online voltsandjolts
« Reply #16 on: January 06, 2024, 12:04:47 pm »
Where did you buy?
Ali-X?
Can you link the store?
« Reply #17 on: January 06, 2024, 12:19:10 pm »
Awww, no cute little histograms on stats like 2000XHD?
Online 2N3055
  • Country: hr
« Reply #18 on: January 06, 2024, 12:28:17 pm »
Histicons?
It should have them.. You can enable/disable them.
« Reply #19 on: January 06, 2024, 03:20:11 pm »
Statistics & Histogram also in SDS1000X HD.  ;D
The following users thanked this post: Performa01, voltsandjolts, Triode71
Offline roy_eedreku
« Reply #20 on: January 06, 2024, 03:28:08 pm »
Any idea on how the Bode plot feature works?
The following users thanked this post: Triode71
« Reply #21 on: January 06, 2024, 03:29:04 pm »
Digital Filter (Low Pass, High Pass, Band Pass and Band Reject) also in SDS1000X HD.
The following users thanked this post: Performa01, Martin72, Triode71
Online 2N3055
  • Country: hr
« Reply #22 on: January 06, 2024, 09:29:44 pm »
Exactly the same as on SDS2000X HD.
Online 2N3055
  • Country: hr
« Reply #23 on: January 06, 2024, 09:30:41 pm »
And if you tap on that small histicon, it opens a large histogram.
Offline Martin72
« Reply #24 on: January 06, 2024, 09:48:53 pm »
This means that the 1000X HD also has manual memory management.
How much 2000X HD is in this scope.....
