Author Topic: Siglent SDM3055 - stuck on boot screen  (Read 50495 times)
Offline dvp
  • Country: ru
Re: Siglent SDM3055 - stuck on boot screen
« Reply #175 on: July 05, 2024, 12:21:39 pm »
My device SDM 3055 is 7 years old, it worked fine. I haven't used it for about a year, but now, after turning it on, it freezes on the download screen. I need help restoring the device, help me.
Welcome to the forum.
Can I ask if this old meter has ever had its firmware updated ?
If No, it must be returned to Siglent for specialized recovery and calibration.
Yes, it was updated, but a very long time ago, about 3 years ago, and I do not remember the firmware number.
Offline rf-loop
« Reply #176 on: July 05, 2024, 03:07:46 pm »
If you have updated it as you said, it is obvious that there is U-disk recovery in the firmware.
2017/4/14 FW 1.01.01.19 1. Added U disk recovery function.
Ref attached version history.
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Offline tautech
« Reply #177 on: July 05, 2024, 09:53:34 pm »
Good, clues to providing a successful recovery are below.
Please send personal message with your email address.
Offline dvp
  • Country: ru
« Reply #178 on: July 08, 2024, 07:39:07 am »
tauech. Thank you, I sent PM
Offline tautech
« Reply #179 on: July 08, 2024, 08:22:37 am »
Email sent yesterday.
Offline dvp
  • Country: ru
« Reply #180 on: July 08, 2024, 07:01:19 pm »
tautech, Thanks! My "dinosaur" came to life and is back in operation, it was version 1.01.01.25, now it has been updated to the latest version. It's working well so far.
Offline Monte Quercus
« Reply #181 on: July 13, 2024, 11:24:35 pm »
Hello and thank you for the welcome!
I just wanted to share that I was able to successfully recover my SDM3055 with the provided files and a SamData 8GB USB Flash Drive as offered on Amazon here: https://www.amazon.com/dp/B092879BVB?ref=ppx_yo2ov_dt_b_product_details&th=1.
Offline concerto51
« Reply #182 on: July 17, 2024, 09:07:51 pm »
Hello, I encounter the same problem. my SDM3055 was not powered up for a few months and today it's stuck on boot screen. I think I already upgraded it to version 1.01.01.19 a few years ago but I'm not sure.
Please can you send me the recovery files.
best regards
Lorenzo
Offline jmg-arati
« Reply #183 on: July 19, 2024, 01:55:16 pm »
Hello everybody !
Unfortunately, my case is not very original. I own a Siglent SDM 3055 who is stucked at boot screen.
It's the second time it happened to me.
The first time I contacted SIglent, and they sent ma a link to a "SDM3055 Recovery by U disk.zip" file that i downloaded, put its files on a 2 GB FAT32 USB disk, and was able to recover my unit from that.
I then installed a more recent firmware (may be the 1.01.01.20...).
But it just happened again yesterday : freeze at boot screen, after the unit stayed without power cable connected for some days.
The bad new is that the recovery USB disk trick don't seems to work anymore ! The 3055 just read quickly the USB disk at startup, but no recovery happens, and it stays frozen...
So what to do ? Maybe you have some useful informations to help me with this challenge ?
By advance, thank you ! Regards.
Offline tautech
« Reply #184 on: July 19, 2024, 01:59:09 pm »
Hello everybody !
Check your messages.
Offline jmg-arati
« Reply #185 on: July 19, 2024, 03:25:07 pm »
Thank you so much tautech !
You were very fast to send me new USB recovery files (different from those sent to me by Siglent, some years ago), who worked like a charm !
I just installed the latest 3055 firmware (the 1.02.01.27R2, followed by the 1.02.01.28, hoping this behaviour will not come back in some months/years.
I will keep an eye on this forum, also. Bye.
Offline vikorona
  • Country: id
« Reply #186 on: August 05, 2024, 09:43:30 am »
Hello,
Today, my SDM3055 also stuck at the start logo screen...
A few months ago it was updated to 1.01.01.25.
Can someone help me with the recovery file?
Offline tautech
« Reply #187 on: August 05, 2024, 09:54:40 am »
Hello,
Offline Hoggy
« Reply #188 on: August 09, 2024, 12:21:36 am »
It seems my SDM3065X has joined the list of frozen boot screen devices.  I haven't used much of my equipment lately, and keep it off using a power-strip to save from things like lightning strikes.
It should already have the latest firmware file that I put on it a few months back: SDM3065X_V3.01.01.12R1.ADS
Offline klausES
  • Restore Sony ES/Esprit era
« Reply #189 on: August 09, 2024, 03:30:03 pm »
If there are no coincidences, it almost sounds as if there is a connection with a longer standstill time.
But what should it be if this would be true ?
A memory that would need a battery or a goldcab is not in my knowledge in the SDM.... ?!?
Is there a flash memory type that could create a long -term problem ?
Would anyone have a possible explanation ?
regards klaus. "Art is when you can't do it ... because if you can, it's not art"
Online nctnico
« Reply #190 on: August 09, 2024, 06:52:07 pm »
Yes, and it is called NAND-flash and it used for storage almost exclusively nowadays. What is needed to use this kind of memory for long term storage is error-correction (redundant) data and regular refresh of the data. If this isn't implemented correctly, a device is likely to fail due to the flash contents getting corrupted over time.
The following users thanked this post: egonotto, tautech
Offline klausES
« Reply #191 on: August 11, 2024, 03:01:22 pm »
I wouldn't have thought that from Flash memory.
Thought that some cells could eventually be damaged by a large number of writing processes, but not from a standstill.  :-\
That horrified me now.
Offline dbouvier
  • Country: uy
« Reply #192 on: August 17, 2024, 02:11:31 am »
Hi, I'm a long time reader of the forum, first post.
Recently I've bought an used SDM3055 on Ebay and the seller forgot (😏) to mention that it was stuck at boot screen. I plugged an old 2Gb pendrive (the only one my Rigol scope is able to read) and the "activity" light on the pendrive blinks, so I think the DMM is trying to read it.
Can somebody help me providing the required files to recover the DMM?. I will very much appreciate it. Of course I will upgrade the FW to the last version after recovering.
Have a good day!!
Offline tautech
« Reply #193 on: August 17, 2024, 02:14:14 am »
Have a good day!!
Offline BillyGo
  • Country: ie
« Reply #194 on: September 03, 2024, 02:35:41 am »
I have an SDM3055 that’s stuck on the boot screen as well.
I’ve noticed that my unit doesn’t have an SD card slot inside.
It seems like attempting the USB recovery is the only choice, can I have the necessary recovery files? Any help would be greatly appreciated!
Offline tautech
« Reply #195 on: September 03, 2024, 03:46:16 am »
PM sent
