Author Topic: Siglent SDM3055 - stuck on boot screen  (Read 45213 times)
Offline Joe510070
Re: Siglent SDM3055 - stuck on boot screen
« Reply #50 on: November 28, 2021, 07:48:37 pm »
I’m having a similar problem but with only a dark display. I posted the details in the repair section of this forum. Hopefully there is hope for me too!
Offline JimLev
« Reply #51 on: January 16, 2022, 12:18:07 am »
First post. I found this forum yesterday after a quick search. My 18 month old Siglent SDM3055 was stuck on the boot screen.
I sent Tautech a PM and almost instantly he replied back, thanks again Tautech.
He emailed me what I needed to fix my meter and to upgrade the firmware to the latest version.
Great forum, I’ll have to cruise around and see what else I can find.
Jim L
« Reply #52 on: January 16, 2022, 09:42:32 am »
To all those following, latest firmware should put an end to all this as the important feature in it is:
Optimize flash R&W design.
Anyone with a SDM model please install the latest version.
Pick the version to match your model from here:
https://int.siglent.com/download/firmwares/?CateIdss=5
Offline Neox_Dev
  • Young "french" hobbyist with adhd and asperger
« Reply #53 on: February 03, 2022, 12:36:41 pm »
Hi guys, the same happened here with my SDM3045X does anyone could provide me the recovery tool please?
« Reply #54 on: February 04, 2022, 06:53:06 am »
Welcome to the forum.
Received your PM and will contact you when back from holiday next week.
Offline MWilliams
« Reply #55 on: February 10, 2022, 04:15:09 am »
New to the forum with a new Siglent SDM3055X and right out of the carton it powers up and freezes on the splash screen. I've read in this posting that the new firmware no longer does this so I'm guessing this unit must have been sitting in an Amazon warehouse for quite while. If I can get that repair/fix it would be most appreciated.
Offline Kleinstein
« Reply #56 on: February 10, 2022, 06:37:58 am »
If it is dead right out of the box, this would be something to send back for an exchange on warranty.
Offline idris5416
« Reply #57 on: February 25, 2022, 11:47:34 pm »
Hi everyone
i got my brand new SDM3055 and press on button then dada siglent logo, almost 2h still there, looks like stuck. Any possible way to recover?
Thank you.
Offline farj
  • Country: ar
« Reply #58 on: March 04, 2022, 07:29:25 pm »
Hello everybody,
I’m a brand new member.
I had the same renowned problem with my SDM3055x and member Tautech (Rob) kindly helped me out to bring it back to life (with the recovery package). It’s now working with the latest firmware 1.01.01.25.
Thank you very much Rob. Excellent person and excellent forum.
The following users thanked this post: tautech, Mortymore, AVGresponding
Online Electro Fan
« Reply #59 on: March 05, 2022, 06:35:22 pm »
How’s that Siglent stock price doing after their IPO?  Whatever the current stock price is it would be higher if they hired tautech.
Offline WillyCrash
« Reply #60 on: April 04, 2022, 10:29:50 pm »
My SDM3055 stuck on boot screen, contacted tautech within a very short time I was back in operation.
Thank you tautech
Offline sjb
    • Altointegra Ltd.
« Reply #61 on: May 13, 2022, 09:35:51 pm »
My SDM3055 has been running 1.01.01.25 since last September. Used it more times than I can remember since then. Just powered it on and it's hung at the splash screen. So, not convinced that the latest firmware is bug free!
I've messaged @tautech in the hope he can help me.
Back to using an old Meterman 37XR handheld 3.5 digit for the weekend!  :'(
« Reply #62 on: May 14, 2022, 02:30:52 am »
Check your emails.  ;)
Offline sjb
    • Altointegra Ltd.
« Reply #63 on: May 14, 2022, 03:05:19 pm »
Thanks @tautech, I tried the recovery on numerous USB sticks (all FAT32 formatted and less than 16GB), USB LED just flickers a few times at start-up then nothing, it still just sits there on the splash screen. You can see the green LED of the micro through the back panel slots and that is on solid flashing off twice about every second, so there is activity, not sure what it should be doing under normal operation or during boot(?).
Has this recovery been tested with 1.01.01.25? I'm a bit sceptical that the last update (25) was to "Optimise the Flash R/W" ... has that had any effect on the ability to do a recovery? Has it made the hang more prone rather than fixing it?
Any Idea's what else to try? I thought from the previous posts it would be fairly straight forward, but I'm not beaten yet!
Can a recovery be done using the internal SD card slot? Is there a recovery package available for that? I guess that would wipe the calibration though!
Offline sjb
    • Altointegra Ltd.
« Reply #64 on: May 21, 2022, 01:45:36 am »
Can someone do me a VERY BIG favour!
Can someone Telnet into an SDM3055 (root,ding123) and copy the filesystem to a USB stick:
cp -R /usr/bin/siglent /usr/bin/siglent/usr/mass_storage/U-disk0/
... then message me with (or post on here) a file listing of your /usr/bin/siglent/firmdata0 directory and the contents of these 2 files:
/usr/bin/siglent/firmdata0/DMM_Calibration.xml
/usr/bin/siglent/firmdata0/NSP_System_Info.xml
I've restored my Serial Number after a failed U-Disc recovery (ended up doing a SD U-Disc Recovery!), but the Info Screen now doesn't show 'Production ID : SDM3055' anymore, the line just isn't there! So, I'm wondering where that is stored in the system files.
NSP_System_Info.xml:
<?xml version="1.0" encoding="UTF-8"?>
<nsp_system_info_root>
  <device>
    <system_information>
      <serial_number>
        <chip>SERIAL NUMBER GOES HERE</chip>
      </serial_number>
    </system_information>
  </device>
</nsp_system_info_root>
Also, My calibration file is empty:
DMM_Calibration.xml:
<calibration/>
Not sure if this is the user calibration or factory calibration?? If it's the latter, it would be good to know the format of the calibration data from a good file so I can get it baseline cal'd locally, although it doesn't look too bad calibration wise as-is.
Thanks in advance!
« Last Edit: May 21, 2022, 01:48:44 am by sjb »
Offline tv84
  • Country: pt
« Reply #65 on: May 21, 2022, 07:51:43 am »
Usually model names are stored in .cfg file and are reloaded by a siglent.cfg update file.
I don't remember if that is exactly the case in a SDM.
Offline sjb
    • Altointegra Ltd.
« Reply #66 on: May 21, 2022, 03:07:36 pm »
@tv84, do you have any info on the format or content of the siglent.cfg file?
@tautech, have you got a SDM3055 that you can extract the /usr/bin/siglent/firmdata0/ files from ... just as a reference to compare with what I have in mine.
Offline tv84
  • Country: pt
« Reply #67 on: May 21, 2022, 03:57:07 pm »
Not sure it exists. We would need a dump from someone's filesystem to be sure.
Offline dibro
« Reply #68 on: May 21, 2022, 04:39:28 pm »
@sjb, attached the dump of my SDM3055 with Serial removed.
This is from when I received the device in August last year.
The calibration file may not be correct for you device.
« Last Edit: May 21, 2022, 04:41:17 pm by dibro »
The following users thanked this post: sjb
Offline sjb
    • Altointegra Ltd.
« Reply #69 on: May 21, 2022, 06:00:20 pm »
Big thanks @dibro, I'll check it it later. One question, is your SDM3055 just factory calibrated or has it had a user cal applied? ... just so I know what the cal is possibly referring to.
Offline dibro
« Reply #70 on: May 21, 2022, 06:03:12 pm »
Factory calibrated.
Offline sjb
    • Altointegra Ltd.
« Reply #71 on: May 21, 2022, 06:53:12 pm »
Well, I've now restored the serial number (in NSP_system_info.xml) and the device descriptor (in NSP_trends_config_info.xml). So the system information now reports all the right stuff.
Just need to get the device factory calibrated now!
Offline etiboss
« Reply #72 on: September 17, 2022, 03:35:36 pm »
Hello All,
My SDS 1052DL+ froze on the boot screen, I tried the hard reset with the math button but it's not working. Is this possible to have the usb recovery package suggested in the previous posts?
Thanks for the Help.
Offline foxbib
« Reply #73 on: November 21, 2022, 04:32:29 pm »
Hello everyone,
I'm new here !
As others, i have a Siglent SDM 3055 stuck on boot screen.
@tautech: Can you send me plz the magic kit :)
Thank you
Offline foxbib
« Reply #74 on: November 25, 2022, 10:46:46 am »
Hello,
Thank to tautech, i was able to recover my SDM 3055.
And now i'm upgrading all my devices  :-BROKE
Have a good day.
