I stopped this project, parts are still available if someone wants them ( negotiable ) , costed me 130$ Cad, ( cant recall, but maybe enough parts for 2 boards or more minus the relays, (have only 2 of them) not the same foot print for the resistors, i could make a board the same size has the original one, but moved on to another stuff
The biggest problems was to find the same precision resistors parts, here in Canada, i did not have many choices.I dont have the pm6304 lcr meter anymore ... i have an Sencore Lc102 instead.
No pcb's where done,
managed to output a gerber file Highvoltage was kind enough to send / lend me an original board of his 6306 lcr meter, had put countless hours to patch and fit the parts, it was my first attempt to make a board design.
It was made with easyeda, im having a hard time to work with this interface. The board routing was a nightmare, it would not place the parts correctly at the tiime
Remove all .txt extensions
Changed the First thread title, project stopped.
