I was going to add a reply to a current thread about the 3045X but I was thinking maybe because I present a new question at the end, I should start a new thread. I trust the sysops will keep me right.
I have tried very hard to like my new Siglent 3045X Bench Multimeter - it is built into a proper steel case, beautiful LCD but it more or less stops there for me. It is indeed a first for me I am going to sell a piece of gear that is less than 6 months old and I will take the hit on cost.
For the record, the relay activation when measuring above 2V is so damn annoying. It occurs whether in Manual or Auto. - its not the noise , its the delay every single time you apply the probe to a point to be measured. OK, so the first thing I do at switch-on is set it to manual 60V which covers most of my bench work and gets rid of the annoying click. But what a PITA. I thought I was getting a nice multimeter experience but I can't see the low contrast blue on grey writing as used by the shift key, the thing clicks like crazy and the menu system is somewhat convoluted for me. Why can't you have a setting that allows it to restart in the same config as when you turned it off ? The SDS2000X Plus and the SVA3021X do this. Presumably the B-team were set to work on the cheaper bench meter.
What made me realise I was flogging a dead horse is that I usually switch on my trusty old cheap chinese VC8145 which apart from the flimsy case and the rather old hat (but gorgeously large and clear) display seems better in so many ways. Assuming the Siglent is accurate and within spec, then the VC8145 is too - they are extremely close on all ranges. Not much point in having the Siglent if it is the VC8145 that I instinctively choose for each session.
But I won't be defeated, for my retirement hobby and the occasional piece of work that still comes my way I like the idea of a good bench meter that is readable, has a screen like the Siglent, easy to use, doesn't click every time you make a measurement, switches on quickly, remembers the last settings and doesn't move around the bench when you press buttons. A test intrument that makes me feel happy to use, like my new SVA3021X and SDS2000X plus which are just great.
Any suggestions as to where I go once the 3045X has gone to a new owner. Apart from staying with the VC8145 which ticks many of those boxes (when glued to the shelf that is...
Cheers
Eloso
