Thanks for the responses.
From what I am reading, it seems that is "by design" especially because the meter was designed with other "requirements" in mind.
Here is what is bugging me:
I did a comparison between the Rigol and the HP multimeters.
I ran the same test for both as follows:
Measure voltage across probe when DUT is set to diode:
Rigol: 5.7V
HP: 6.85
Measure of Current in series while testing the LED:
Rigol: 1mA (in fact a bit less 0.995, maybe due to burden load)
HP: 1mA (in fact a bit less 0.995, maybe due to burden load)
So my conclusion is that even though both meters are generating in enough voltage/current to be able to measure, there must be a threshold setting and the voltage drop of a led is outside the range programmed in the meter. I think that is what TimFox was referring to.
so the diode may light but the meter is programmed to indicate off-scale or overload at typical voltages.
In fact, I just referred to the manual one more time, and it is actually stated but I did not know how to read it.
To Check Diodes
Test current source: 1 mA
Maximum resolution: 100 μV (range is fixed at 1 Vdc)
Beeper threshold: 0.3 volts ≤ Vmeasured ≤ 0.8 volts (not adjustable)I am thinking this means that the beeper will beep as long as the voltage in which the DUT starts conducting is between 0.3 and 0.8.
In the curve tracer I can see that the led I am testing starts conducting at ~1.5(outside the threshold) were the diode conducts at around 0.5V which is in the threshold.
Did I get this right?
Not sure how to read the specs on the Rigol:
Test Current Source: 1 mA, 100 μA, 10 μA, 2 μA, 200 nA
Voltage Measurement Range: -0.2 V ~2.2 V, -0.2 V ~4.2 V, -0.2 V ~4.8 V, -0.2 V
~5.2 V, -0.2 V ~5.5 V
Max Resolution: 100 μV
Input Protection: 1000 V Input Protection.
Open-circuit Voltage: < 8 VThanks!
