The hardware for the SDM3045/SDM3055S-E is slightly different from the full SDM3055. However the difference is with the accuracy of parts (more stable divider and reference) and may very well not effect the firmware side. So the same firmware should run on both. The E version is a cheaper version with reduced accuracy, but the same ranges.
