Hmmm!?
It went through a 'slave' upgrade process then failed on a Host upgrade .... now what do I do?
(Attachment Link)
Gimme a few minutes and I'll update one I have here..................
Retried with another (re-formatted and older) flash drive, with only the firmware file on there, and it worked
Now at .21
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
My observations:
The upgrade .ADS file is best in the root of the USB drive as with the 1.19 release firmware, folder navigation is problematic and I had 2 freezes !
![Flogging A Dead Horse :horse:](https://www.eevblog.com/forum/Smileys/default/DeadHorse.gif)
Best if you use a USB stick with an activity LED so to keep an eye on progress.
The system keeps checking the USB stick contents even though you have navigated to the correct ADS upgrade file.
Unless a ADS upgrade file is navigated to, the OK button remains greyed out.....but still the USB activity light remains active.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
After OKing the firmware install, nothing at all happens for some seconds
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
but finally the update starts and only lasts a short time until the OS then starts the overwrite which takes just a short while too.
For both the upload and install/overwrite progress bars are displayed.
The SDL then self reboots and inspection of the System info reports the 1.21 version.
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
We hope
3. Fix several bugs has addressed these firmware update issues.
Update log:
Select update (press OK) .......20s delay before any further activity. >
Upload update 45s >
Overwrite existing FW 20s >
Self reboot.
Total elapsed time ~1.5 minutes.
