New range of highly featured dual channel AWG's.
![](https://www.siglent.com/u_file/product/21_04_07/1.png)
![](https://www.siglent.com/u_file/product/21_04_07/4.png)
SDG7032A 350 MHz
SDG7052A 500 MHz
SDG7102A 1 GHz
Released March 2022
Features
Dual-channel differential or single-ended analog outputs
24 Vpp analog output capability with ±12V DC bias, maximum ±24V (48 V) output range (See datasheet)
5 GSa/s digital-analog sampling rate and 14-bit vertical resolution
Mem depth 512 Mpts
Sine, Pulse, ARB, PRBS, Noise and IQ (option) waveforms
Arbitrary waveform sampling rate 2.5 GSa/s and vector waveforms to 500 Mb/s
PRBS patterns up to 312.5 Mbps
AM, FM, PM, FSK, ASK, PSK, DSB-AM and PWM analog and digital modulation
Minimum pulse width 1 ns and minimum Rising/Falling edge 500 ps
Hardware frequency counter
5 inch capacitive touch screen, resolution 800x480; supports external mouse and keyboard
I/O; USB Host, USB Device (USBTMC), LAN(VXI-11/Telnet/Socket), external modulation/frequency meter input, reference clock Input, reference clock output, Marker output, Trigger In/Out, etc.
SCPI remote control
WebServer
Wireless mouse supplied
Options
Digital bus 16-bit, LVTTL or LVDS output Bit rate 1 μbps ~ 1 Gbps
10M_OCXO (factory install only)
IQ signal generation function (software)
Datasheet:
https://int.siglent.com/u_file/document/SDG7000A_Datasheet_EN01A.pdfhttps://int.siglent.com/products-overview/sdg7000a/https://www.siglenteu.com/waveform-generators/sdg7000a-arbitrary-waveform-generator/https://siglentna.com/waveform-generators/sdg7000a-arbitrary-waveform-generator/
