Author Topic: Siglent SDG5000 / SHS800 - upgrade hack/unlock (SOLVED)  (Read 10869 times)
Offline tv84Topic starter
  • Country: pt
« on: July 28, 2018, 07:01:56 pm »
Has anyone with a Siglent SDG5000 series or SHS800 series done a BW upgrade on them?
Edit: Added the SHS800 SCPI commands list. (something that Siglent says they don't have...)
« Last Edit: September 28, 2019, 08:38:24 pm by tv84 »
The following users thanked this post: natman69
  • Country: pt
Re: Siglent SDG5000 / SHS800 - upgrade search?
« Reply #1 on: August 29, 2018, 10:07:35 pm »
No pain, no gain...  ;)
My big thanks to the volunteers who accepted the challenge.
It's perfectly possible to upgrade these equipments.
The SHS800 series (804, 806, 810 and 815) behave as a SDS1000CML. If you run a SCPI command "MD5_PR?" they will report the product_type "SDS1000CML".
So, I guess looking at the FW, the SHS820 series (820, others?) behave as a SDS1000CNL. Anyone with a SHS820 can confirm this doing the "MD5_PR?".
(And that validates the HWs are really different beteween the 2 series and their corresponding FWs.)
But if that is the case, and since the FW has references to the SHS830 model, maybe it's perfectly possible to upgrade a SHS820 to a SHS830 (300 MHz).
The results so far, are attached.
« Last Edit: August 30, 2018, 09:50:39 am by tv84 »
The following users thanked this post: pantelei4, BillB
Offline BillB
« Reply #2 on: August 29, 2018, 11:22:43 pm »
Nice work, tv84!  :clap:
  • Country: pt
« Reply #3 on: September 04, 2018, 08:58:53 pm »
BTW, can't understand how Siglent says that SHS800 (and almost certainly the SHS1000) "don't support SCPI commands"!?!?!!!   :o :o
https://www.siglentamerica.com/operating-tip/siglent-products-support-scpi/
https://www.siglentamerica.com/operating-tip/siglent-products-support-scpi/?pdf=1293
Among other commands, this was received from a SHS806:
>>>*IDN?
*IDN SIGLENT,SHS806,SHS08Dxxxxxxxx,5.09.01.05
>>>MD5_SRLN?
SHS08Dxxxxxxxx
>>>MD5_PR?
SDS1000CML
>>>MD5_CMPY?
SIGLENT
I swear I didn't implement them!!   :-DD
Re: Siglent SDG5000 / SHS800 - upgrade hack/unlock (SOLVED)
« Reply #4 on: August 01, 2019, 09:58:57 am »
Interested as to how this was done on a SHS as there's only USB and a micro USB I/O's to work with.  :-//
Out of office and unavailable for a few days.
  • Country: pt
« Reply #5 on: August 01, 2019, 10:08:36 am »
If those are the only holes, then for sure it was through one of them... :)  (read my previous msg)
Opening the case it's not a pretty option.
« Reply #6 on: August 01, 2019, 10:15:04 am »
Ah, OK, micro USB to RJ45 cable ?
Shame I don't now have one to play with.  :(
  • Country: pt
« Reply #7 on: August 01, 2019, 10:20:19 am »
Shame! Let's make a deal: a 806 for your SDS5K ?   :-DD
« Reply #8 on: August 01, 2019, 10:30:26 am »
:P
Got a dead 806 PCB set from a repair so I can see the I/O's and the juicy Jtag header.
Offline LPS
  • Country: bh
« Reply #9 on: September 28, 2019, 05:20:41 pm »
Hello,
Can someone kindly post more specific instructions on how I could increase the bandwidth of my SHS806 to that of the SHS815.Reading through this thread, tv84 has shown its possible to do.
I have done a bit of playing about, with Siglent’s EASYSCOPEX I can send SCPI commands to the SHS806.  Using trial and error I managed to be able to change the serial number of the unit with the :SRLN <serial number> command which the unit will recognize as verified when checked with the System Status.
The serial number for the SHS806 has the format SHS06DAQ1RXXXX.  If someone can tell me the format of the SHS815 serial number please, maybe if I change specific characters to the correct letter, then upon boot up the firmware will hopefully recognize it as an SHS815.  I can not figure out how to change the System Status (Firmware) to recognize my SHS806 as a SHS815 Product Type.
Anyways, would appreciate some help.  I am quite inexperienced with SCPI and using terminal etc, so pls be quite explicit.
Thanks
Len
  • Country: pt
« Reply #10 on: September 28, 2019, 08:41:06 pm »
To change BW you need to use the MCBD command. And for that you need the BW license.
You can't change BW just by playing with the S/N.
You can play with the SCPI commands that the equipment supports (see the list in the 1st msg of the thread).
The following users thanked this post: LPS, rubennss, kosomsk
Offline daveyk
« Reply #11 on: June 19, 2020, 11:10:36 pm »
Reports as a SDG5162, but only goes to 100MHz; not sure why.  I will probably put it back to a SDG5082. If the problem persists that I am having with it, as I will sent it to Siglent (for which I am guessing is an SPCI issue which they will not duplicate of fix).
« Reply #12 on: June 20, 2020, 02:11:46 am »
Check datasheet output amplitude spec.  ;)
  • Country: pt
« Reply #13 on: June 22, 2020, 08:52:40 am »
Anyone has a SHS820 and wants to try upgrade it to 300MHz?
« Last Edit: January 30, 2021, 12:07:10 pm by tv84 »
Offline natman69
« Reply #14 on: January 09, 2021, 12:18:50 pm »
I've a "poor" SHS806 (older HW revision than tv84) and was reading this interesting post.
Not sure if the update can be done only with SCPI commands and where to find BW license or maybe through a modified .cfg file.  :-//
Do I need a microUSB to RJ45 adapter (expert user tautech was mentioning above) to have access to the device through telnet or is it enough to connect with USBTMC interface? |O
Hope some expert user can help me! Thanks in advance!
BTW: I've noticed there is a "new" firmware release 5.09.01.07 from march 2020.
Offline natman69
« Reply #15 on: February 06, 2021, 05:32:24 pm »
With the precious help of tv84 I was able to upgrade my SHS806 to 150MHz. :-+
I did some pictures of a sine wave at 100 and 120MHz.
I am impressed of the knowledge of tv84 about the firmware of this instrument (and others, of course). Chapeau!!!
Offline fsigloch
« Reply #16 on: February 08, 2021, 10:36:02 am »
Hi how you have done this ?
fsigloch@yahoo.com
Offline Photoman
    • PrePress Express
« Reply #17 on: February 09, 2021, 07:28:22 pm »
I also have a SHS806 and it would be great to have a guide o how to "upgrade it".
Thanks!
Offline tobi1024
« Reply #18 on: February 09, 2021, 08:32:21 pm »
Same here.. I own a SHS806 and would be glad to get some additional hints how to upgrade it.
Thank you
  • Country: pt
« Reply #19 on: February 10, 2021, 12:49:45 pm »
Due to several family requests here is the patched FW.
1. Before Patch
*IDN? => *IDN SIGLENT,SHS806,S/N,5.09.01.07
2. Right after patch and reboot
*IDN? => *IDN SIGLENT,SHS804,S/N,5.09.01.07
3. Send the SCPI command
MCBD xxxxxxxxxxxxxx
4. After command and reboot
*IDN? => *IDN SIGLENT,SHS815,S/N,5.09.01.07
Attached is the FW that allows Siglent SHS80x to go to 150MHz.
You just have to search the forum for the generator that allows you to fill the xxxxxxxxxxxxxx.
The following users thanked this post: Photoman, tobi1024, CrankyBot
Offline Modry
« Reply #20 on: February 13, 2021, 12:16:37 pm »
Please help, I have a SHS806, I am making a mistake somewhere and I don't know where  :-//. I installed version *IDN SIGLENT,SHS804,SHS08DAC1L1114,5. 09. 01. 07. Now I am trying to generate the MCBD value but I am unable to read the SCOPEID. SCOPEID command? returns the error "Failed to read or write comands!" I am also not sure if I am selecting the Model correctly in the generator script (SDS1000CML)
  • Country: pt
« Reply #21 on: February 13, 2021, 02:43:29 pm »
Use S/N.
The following users thanked this post: Modry
Offline maex
« Reply #22 on: February 13, 2021, 05:11:51 pm »
How can I mod the firmware for the SHS1000?
  • Country: pt
« Reply #23 on: February 13, 2021, 06:57:04 pm »
I never did it. Maybe one of these days...  I think you are the only owner in the world!  :)
Offline Modry
« Reply #24 on: February 14, 2021, 12:27:06 am »
A complete success, congratulations on your knowledge and thank you for your help.  :clap:
