trying to do this hack to my SDG2042x Firmware V2.01.01.38
Im trying to find a link to the actual script to create the keygen etc, the putty bit ive had no issues with, but all the links ive found (including the two in the SDS scope thread) go to here
https://replit.com/repls/ElasticEnormousMice and it says "page not found" even after ive logged in
All of Martins other steps have worked, i just cannot create the keygen without the script.
thanks in advance!
Edit; Found a script here
https://pastebin.com/fygAJy6y , for the "ScopeID" line of the code i entered my S/N, Model as 'SDG2000X' changed the '150M' setting to '120M' then compiled it using an online util here
https://www.programiz.com/python-programming/online-compiler/as per previous posts, i double checked that the key generated for the '40M' option matched my current key (logged by sending the MCBD? at the start via the telnet) once i saw that it matched, i realised the python script had worked.
sent the new key in via the MCBD command, works perfect
thanks all! i suppose this also helps anyone else wondering if the latest V2.01.01.38 still allows it... yes it does!
