I was comparing my copy of those instructions to make sure I hadn't missed a more recent version and noticed I had copied the exact same set quoted by @Aqunity who'd noticed a couple of minor typos as mentioned here:
Offline Aqunity
Newbie
Country: ca
View Profile Email Personal Message (Offline)
Re: Siglent SDG2042X Hack door closed
« Reply #89 on: October 03, 2020, 04:55:57 pm »
Say ThanksReplyQuote
Thanks so much John this process worked for me.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I had software version 2.01.01.23R8
Two small things:
When you click the firmware link it doesn't work so copy and paste it into your web browser address bar and remove the comma at the end.
Step 10 should read:
10) computer console, press the ESC key, then type: ":wq" and <RETURN> to save the file
The : in front of the wq is important as it does not work otherwise.
Quote from: john95 on May 14, 2019, 04:44:47 am
recap the steps scattered around to here.
with the rest of his post being as per those very same instructions.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Hopefully, this will help avoid the pitfalls of john95's otherwise perfect recapping of the process he'd gathered into one concise instruction set from the many and separate sources within this (and possibly other) thread(s) - it
is a long time ago now!
[EDIT] Actually, it was July 2020 when I downloaded the collection of telnet ads files and, iirc, this was in anticipation of making an actual purchase of either an SDG1000X or SDG2000X series function generator (I hadn't quite made up my mind over which to go for).
In the end, I went for an SDG1000X and returned it as "Not fit for purpose" by reason of it suffering a rather subtle oscillator fault (flicker noise like phase modulation) that I'd had great difficulty in convincing my supplier and the 'so called' Siglent tech support (including their head of European Marketing!) of the seriousness of this glaring (to me at least) defect, hence my returning it for a full refund and my purchasing an SDG2000X from another of Siglent's authorised UK agents.
The original quoted instructions are now over 3 years old and john95's update just over 2 1/2 years old which is what led me check out my own copy
