Author Topic: software for 16500C  (Read 728 times)
Offline fisafisaTopic starter
software for 16500C
« on: July 01, 2023, 11:51:09 pm »
Hi
I am looking for the following:
E2450  Symbol Download Utility software.
E2423  SCSI inverse assembler
Many thanks
Re: software for 16500C
« Reply #1 on: July 02, 2023, 07:08:32 pm »
Hi.
I really do not know.
It is not included in the 4 disks I have for the 16500C.
They were available as downloads from keysight, but no more now.
Thanks
Filippo
Offline gslick
« Reply #2 on: July 02, 2023, 09:33:07 pm »
Offline gslick
« Reply #3 on: July 02, 2023, 09:51:13 pm »
Hi
The attached .ZIP file contains the following files:
messages
objects
opt5_032
optc_032
opt_032
readme.txt
messages\default
messages\default\alloc.ini
messages\default\design.ini
messages\default\errmsg.ini
messages\default\explain.ini
messages\default\fatal.ini
messages\default\fmgr.ini
messages\default\ns.ini
messages\default\nsr.ini
messages\default\nssrch.ini
messages\default\omfchck.ini
messages\default\omgr.ini
messages\default\readers
messages\default\readers.ini
messages\default\try.ini
messages\default\readers\gpa.ini
messages\default\readers\omni.ini
objects\addr
objects\addr.mod
objects\bintree.mod
objects\clue.mod
objects\instlpk.mod
objects\msgcat.mod
objects\ns.mod
objects\nsaddr.mod
objects\nsr.mod
objects\nssrch.mod
objects\omfchck
objects\omfchck.mod
objects\pk.mod
objects\readers
objects\readers.mod
objects\strtok.mod
objects\symlop.mod
objects\addr\lin32.mod
objects\omfchck\aout.mod
objects\omfchck\elf.mod
objects\omfchck\gpa.mod
objects\omfchck\ieee695.mod
objects\omfchck\omf386.mod
objects\omfchck\omf86.mod
objects\omfchck\omf96.mod
objects\omfchck\ticoff.mod
objects\readers\aout.mod
objects\readers\elf.mod
objects\readers\gpa.mod
objects\readers\ieee695.mod
objects\readers\omf386.mod
objects\readers\omf86.mod
objects\readers\omf96.mod
objects\readers\omni.mod
objects\readers\ticoff.mod
If you have a blank floppy disk, you can copy all of those files to a floppy while preserving the directory structure. Then insert the floppy into the 16500C before you power it on. Then when you power on the 16500C, it will copy all of the files to the SYSTEM directory while preserving the directory structure. That will take a while, longer than you might expect be patient. After the 16500C finishes booting up, the E2450A files should all be installed and the floppy is no longer needed.
If the 16500C is connected to your network, you could also FTP all of the files to the SYSTEM directory of the 16500C. Make sure you select BINARY mode in your FTP client before you transfer the files. Also make sure you preserve the directory structure of the E2450A files under the SYSTEM directory of the 16500C. That might be a bit tedious to do manually, depending on your FTP client.
« Reply #4 on: July 07, 2023, 12:33:32 pm »
Many thanks!
Great community to be in.
Filippo
