Author Topic: Siglent SDG2000X Firmware, Hardware, Software Versions  (Read 5640 times)
Offline hpw
Re: Siglent SDG2000X Firmware, Hardware, Software Versions
« Reply #25 on: July 06, 2023, 12:06:27 pm »
Yeah, I loved this latest release...
Counter dead after xxx counts as system locked up completely..  so switch off/on button helped O;)
Still a nightmare those Siglent gear.
Thanks, that's really helpful....not !
Please write it up in detail here and attach a State file from your AWG.
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/
TIA
As I did some counter measurement on 10MHz again...
1. did hang, as running > 15 Min screen saver ... >> power off > power on cycle to get it back running
2. did change the the screen saver to 1 Minute: also hangs after hangs, sometimes the the screen activation did not runs... so as hooked up
3. disabled screen saver completely, so on magic count 935, device hooked up
Please, Can some one confirm this situation repeated hook up... as let them run without screen saver for hours  :phew:
Hp
Online Martin72
  • Testfield Technician
« Reply #26 on: July 06, 2023, 12:13:05 pm »
Could check this in the evening with my SDG2122X and Bodnar pulser
(Kierkegaard)
Online Martin72
« Reply #27 on: July 06, 2023, 08:14:57 pm »
Test it...
Screensaver 1min, 5min no problem.
Screensaver 15min, system hangs, only off/on will help.
Screensaver off, after 1564 counts (fast mode) system hangs, only off/on will help.
Clearly a bug.
Mine:
Firmware 2.01.01.37R2
Hardware 02-02-00-40-00
Martin
Edit:
It seems I don´t have the latest firmware installed - did you have it ?
Interesting: My firmware version seems not to exist in the revision history
@Tautech : Would be good if the systeminfo will display the hardware revision mentioned in the firmware revisions, F...G...etc.
(Kierkegaard)
Offline hpw
« Reply #28 on: July 06, 2023, 08:40:16 pm »
Thanks for testing,
I run the latest FW, as posted on previous page with given bug.
So it looks as an old feature O;)
hp
Offline tautech
« Reply #29 on: July 06, 2023, 08:41:27 pm »
Test it...
Clearly a bug.
Mine:
Martin
Edit:
V2.01.01.37R6 is latest, install it.  ;)
From release notes:
1.Compatible with Rev.G hardware
2.Fix the bug that the system does not respond when there is no operation for a long time after the counter is turned on
Out of office and unavailable for a few days.
Online Martin72
« Reply #30 on: July 06, 2023, 08:47:08 pm »
I know the notes, I´ve  posted a pic from it.. ;)
But:
Nevertheless I´ll update my gen and then test again.
(Kierkegaard)
Offline hpw
« Reply #31 on: July 07, 2023, 08:40:44 am »
As "V2.01.01.37R6 is latest, install it." did helped to fix the issue!
Hp
