Author Topic: Siglent SDG1032 high level limited to low ...  (Read 1572 times)
Offline 2N3055
  • Country: hr
Re: Siglent SDG1032 high level limited to low ...
« Reply #25 on: May 25, 2024, 09:17:42 pm »
It's a silly argument to pretend that one brand's pedigree is superior to any others. All the major A brands have many areas of workflow that are unique to their brand. That's been true for decades.
It is not a silly argument. Pedigree means having incorporated decades of customer feedback. It is utterly foolish to ignore that and go ahead re-inventing a square wheel.
Don't be silly. There many things that get obsolete and that changes the paradigm so much that brand new products are equally new ground to startups and 100 years old companies.
Actually, the old "pedigree" companies can be so set in their ways that they resist innovation and get left behind.
That is actually what happened to Tek and digital scopes many years ago. It took them many years to become relevant again, but never such a dominant player like they used to be.
The following users thanked this post: tautech, KungFuJosh, mawyatt
Offline mawyatt
« Reply #26 on: May 25, 2024, 09:30:01 pm »
Same happened to HP/AG/KS :-[
Best,
~Wyatt Labs by Mike~
« Reply #27 on: May 25, 2024, 09:31:21 pm »
Best,
HPAK is easier to type.  :P
Offline Martin72
  • Testfield Technician
« Reply #28 on: May 25, 2024, 10:12:18 pm »
At work we have function generators from Siglent, Rigol, GwInstek and Keysight/Agilent.
What they all have in common is that their display shows the value that is set at a load of 50 ohms.
If the load is not 50 ohms, the actual value is higher.
New colleagues learn this "lesson" the first time they use these devices, they are surprised once, then you explain it and then they know.
It's quite simple.
(Kierkegaard)
The following users thanked this post: thm_w, KungFuJosh
Offline ebastler
« Reply #29 on: May 26, 2024, 05:00:04 am »
[...] their display shows the value that is set at a load of 50 ohms.
It's quite simple.
It's also not what this discussion is about.  :P
