Becouse my tests (jitters etc) are not yet ready and becouse many peoples like pictures. Here is some...
What I can say about building quality.
It is good.
It is not state of art or "high-end" but also price is not.
If front panel and everywhere read example Agilent and I open equipment.. I just believe it.
Only case is made littlebit cheap.. but mainly it can see only inside equipment metal and plastic works finishing.
Yes there is not Swizerland watch maker factory drilling, milling and lathed diecast aluminium fine cast alloy chassis like some Agilent high-end units. This kind of empty chassis price alone is maybe more than some lot of these equipments.
Where is this chinese crap quality?
Also I have not find any dirty and badly hand soldered things, and all boards are very clean, no fingerprints, no dirty residues.
TFT panel have real glass front of it. It is really nice detail
Note for display image, it is sofft for avoid digital camera and TFT "Moire" interference.
Still there is some, in nature it looks just normal TFT. Color what looks in picture near grey it is very neutral grey in nature.
This model do not have fan. Some models have fan and it is right side of unit. Also left side have air holes. (some other equipment may use same base and also there is place for fan.
I have heard lot of lark about Siglent bad quality. Where it is? Maybe it hide inside these plastic/rubber parts what all are made from recycled material. Maybe this bullshit and crap are lying hidden inside plastic... you have been warned.
Btw.. under backside BNC connectors position there is place for TCXO or maybe for small OCXO on the main board. (U107)
Whole unit is in strong metal box (coated iron), also front and back is closed.. outer case is aluminium. Only part outside metal box is front panel + TFT. Power supply is in its own block behind 1mm wall so switch mode power noise is some amount isolated.
What I do not like but still can accept.
1. Output stage is not isolated. (good real isolation is expensive so this need accept. If do cheap isolation - better without it.)
2. Power switch is one pole switch so there may still be "live" (and protective ground) after switch off). There is not main switch. Now if this unit is with optional better internal frequency reference there is not stand by power for keep its powered for keep stability (example OCXO).
(Of course normal serious lab use "house standard" where all equipments are connected. But for this there is other small problem. This unit need initiate for external reference allways after it is powered up and there is not any indication for real reference status (example "locked" indicator))Pictures have they own story...
