But NSP_limit_data.xml is under config and not under firmware0.
You have full instructions in document "SDG1000X Modification instructions V33R1" what you have from zip package where is included exactly all. All commands, all what you need, even after pdf there is also plain txt file for use copypaste for commands. There is also one suitable terminal software and all other things needed. Why you did not read it *). You think that first muscle and after then brain. I recommend to do just opposite.
Read it all, and read it again because you have now jumped over important row. Yes @Orange give just also right one... but is it still better to read all instructions because there is also warnings what must not adjust and if there is not told some adjustment, then do not it just like "try this and try that and after then ...oops" method.
*)And I know you have not read it because you ask this question here.
Thank you,
wouldn't it have been easier to tell me what the mistake is than to review my possible way of operating?
I have already changed the version to SDG1062X.
The only difference is the firmware which is currently 1.01.01.33R1B6: is this the problem?
I think that in a forum we should help ourselves rather than being pedantic!
current mount points are:
rootfs on / type rootfs (rw)
ubi0: rootfs on / type ubifs (ro, relatime)
none on / tmp type tmpfs (rw, relatime)
proc on / proc type proc (rw, relatime)
sysfs on / sys type sysfs (rw, relatime)
mdev on / dev type tmpfs (rw, relatime)
devpts on / dev / pts type devpts (rw, relatime, mode = 600)
none on / sys / kernel / debug type debugfs (rw, relatime)
ubi1_0 on / usr / bin / siglent / usr type ubifs (rw, relatime)
ubi2_0 on / usr / bin / siglent / firmdata0 type ubifs (ro, relatime)
