Author Topic: Siglent SDG 805 boot problem  (Read 25490 times)
Offline tautech
Re: Siglent SDG 805 boot problem
« Reply #25 on: January 10, 2017, 08:58:19 am »
Use Trio's contact page and you might get PM's from some others too, watch for them.  ;)
https://www.triotest.com.au/store/contact-us
Offline tautech
« Reply #26 on: January 12, 2017, 10:48:00 am »
I'm in Brisbane, QLD. I'll refrain from breaking out the screwdrivers ;)
How are you making out with this Jeremy ?
Offline tivoi
« Reply #27 on: June 08, 2018, 01:03:54 am »
hi,  i have same prolemt with shs806
i'm in vietnam, have any service in vietnam
https://youtu.be/gvidRXNwZVw
Offline tautech
« Reply #28 on: June 08, 2018, 10:17:00 am »
I've contacted Siglent for you.
Offline svef
« Reply #29 on: September 06, 2018, 07:35:53 pm »
So, I bought my SDG805, also from Futu Tech GmbH, back in 2014 and used it a bit in the beginning. Have then had a couple of years where my electronics workbench has been mostly collecting dust. Tried using it a couple of weeks ago and got stuck on the boot screen.
I guess I'm screwed. It is definitely more than three years old.
Offline rf-loop
« Reply #30 on: September 06, 2018, 07:51:12 pm »
Contact Siglent.
There is solution.
Do you have installed FW version what support recovery using USB flash. (I guess not if I think your timeline)
If you have this, then it is perhaps more easy. (if your SDG failure is this known type)
If not, there is still solution (including some nice bonus) but it need open SDG and hardware activate recovery mode and then run recovery what need special file from Siglent and after recovery then  remove this hardware activation.
It have many times told that it is very important update to FW version what support USB recovery.
And also now, if anyone still have SDG800 model with OLD FW  then URGENTLY update it to version what supprt USB recovery. Not only support USB recovery but also more new FW do not go to thiss situation so easy at all afaik.
« Last Edit: September 06, 2018, 07:55:34 pm by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
The following users thanked this post: tautech, svef, kucykmar
Offline ratmole
  • Country: gr
« Reply #31 on: February 26, 2021, 08:40:09 am »
is there a recovery image for SDG 805 available?
need it to recover from stuck logo in boot.
thanks
Offline tautech
« Reply #32 on: February 26, 2021, 08:44:21 am »
thanks
Got your PM and returned.
Will go to emails.
The following users thanked this post: kucykmar
Offline jan141282
« Reply #33 on: June 29, 2021, 02:28:19 pm »
thanks
Will go to emails.
Same Problem here can you help me?
Offline kucykmar
« Reply #34 on: August 15, 2021, 11:36:11 pm »
Same problem. Could you help me too?
Offline FlipZ
« Reply #35 on: November 03, 2021, 01:29:23 pm »
I have exactly the same problem with my SDG805 since yesterday. Can you please send me the recovery too?
Thanks!
Offline tautech
« Reply #36 on: November 03, 2021, 02:04:32 pm »
Thanks!
Welcome to EEVblog.
PM sent.
Offline krupka
  • Country: cz
« Reply #37 on: November 03, 2021, 02:15:32 pm »
Hello, I begin to experience bootloop problem with my out of warranty Siglent SDG805.
Could you please send me necessary files.
Much thanks, you are lifesaver
Offline FlipZ
« Reply #38 on: November 03, 2021, 03:55:28 pm »
Thanks!
Welcome to EEVblog.
PM sent.
Thanks for your quick reply and after having to retry the procedure many times it finally worked.
All is looking good again. Many thanks !
Offline rducky
« Reply #39 on: November 18, 2021, 04:19:04 pm »
I am running into the same issue. Unit worked fine last night, this morning it is stuck at the boot logo. Can anyone share the recovery image?
Offline voytec
« Reply #40 on: November 03, 2022, 11:45:06 am »
Much thanks.
Offline DC912
« Reply #41 on: December 31, 2022, 03:27:40 am »
Hello. My SDG805 now freezes on power on at a blue screen—it doesn’t get to the logo screen. The unit was serviced at Siglent several years ago. I would appreciate receiving the files to see if they might correct the problem. Thanks
Offline wattberry
« Reply #42 on: February 27, 2023, 03:49:31 pm »
I switched on my sdg 805 (production date 2017, software in delivery state) yesterday and recognised the same boot problem as described above. This device worked properly well in the past.  I would appreciate, if someone could help me with instructions, files or any other documents. Thank you.
Offline Fryguy
« Reply #43 on: April 11, 2023, 09:27:28 pm »
S*!T , i'm the next one . . .   |O
Can someone be so nice and send me the necessary files and info so i can fix my brick ?  :rant:
Thanks for your help !
Born error amplifier  >.<
Offline tautech
« Reply #44 on: April 13, 2023, 10:23:26 pm »
Received your PM, now check the one from me !  :popcorn:
Offline tautech
« Reply #45 on: April 21, 2023, 07:12:18 pm »
My SDG 810 is dead .  :-BROKE
Now i need to find a new SigGen . . .   :palm:
The next one will not be a Siglent .  :rant:
Please return email about what you have done.
Offline MarcoM_89
« Reply #46 on: May 03, 2023, 09:05:26 am »
Hello, same problem with sdg830 after updating from V1.08.01.15_EN to V1.08.01.15R2_EN. Any solution?
Offline Raz
« Reply #47 on: September 10, 2023, 01:00:53 am »
Can anyone send me the instruction on how to fix a Siglent SDG 805 stuck on boot problem.
Thanks.
Offline tautech
« Reply #48 on: September 10, 2023, 01:02:40 am »
Thanks.
Welcome to the forum.
PM your email address and we'll have you all fixed up.
The following users thanked this post: Raz
Offline Raz
« Reply #49 on: September 10, 2023, 02:44:47 pm »
"Device recovery by USB flash drive", not working for this unit. It stays stuck at Siglent startup screen indefinitely with Kingston or Sandisk 8Gig
flash drive.
