Actually MSO8204A has MSO8000A-BW20T30 so that might enable it. I know on the rigolna.com it lists that option available for MSO8204 as well but it does not work. I do not have a MSO8204A available to test if it unlocks this option but if you want you can drop a message and we'll see
8204 can be cracked to 3G bandwidth I am using 2.10b machine to upgrade mso8000A firmware file name to be changed to mso8000 after going to upgrade after the crack
