So apparently a loose PCB in the probe is a common problem and they send you a replacement when you send them a picture of a faulty one. So that solves most of it.
For the rest, if the PCB inside the probe moves, then just drill a hole through the outer shell of the probe and inject some hot glue to fixate the PCB. (Of course after you've received confirmation you get a new probe).
As for the probe switch. Sure you can do low frequency stuff with the switch set to 1:1, and it lowers the noise floor, as there is less amplification in the scope, but you can do that with any wire.
The advantage of a 1:1 probe is that it
isn't just "any wire" & offers you the same convenience you get with a X10 probe.
The clip will usually stay where you put it, & slipping the end off the probe, you have a nice slim point for "back probing" plugs or looking at the pins of ICs, etc.
Along with a BWD 845 Oscilloscope, I recently acquired a switched probe, also from BWD.
After 50 odd years, the switch still works perfectly, the probe is little thicker than the modern "El Cheapos" I have, but not obtrusively so.
Of course, in 1970, it probably cost a couple of day's wages, so it should have been well made!
When I was at the TV Studio, there were always a few dead Tektronix probes around which could be rebuilt into "Frankenprobes".
They were officially "written off", but found their way into my toolbox, as they were perfectly OK when rebuilt.
I was told to take my toolbox with me when I left, so I did so, complete with rebuilt probes & a few probe corpses.
That was a long time back, so the "Frankenprobes" have all run out.
The cheap secondhand Tek probes from the USA appearing on eBay become unaffordable when the ridiculous shipping quotes are added to the price, so in Oz, they are pretty much not worth the effort.
Strangely, again on Oz eBay, it is cheaper to buy Chinese "El Cheapo" probes through ostensibly Australian sellers than direct from China, & they aren't all that much more expensive "across the counter" at "bricks & mortar" shops.
