Author Topic: Siglent New SDS800X HD First Bactch Unboxing And Tests And Teardown !  (Read 46615 times)
Offline PELLTopic starter
  • Country: cn
DISCLAIMER: This is NOT my machine, and I DONT have real-life access to it. One of my friends purchased it and shared some test results. I own a DHO800 and do some noise compare.
This post is more like a placeholder because I don't own this machine. But still, it is very interesting to see it compare against to the rigol.
Update: This thread is updated at any time, so please check every post I made here, hope you have a good time while browsing this! :-+
« Last Edit: December 30, 2023, 03:08:36 am by PELL »
The following users thanked this post: egonotto, thm_w, Mortymore, ch_scr, Antonio90, sebyon
  • Country: cn
Re: Siglent New SDS800X HD First Bactch Unboxing And Noise Compare With DHO800
« Reply #1 on: December 24, 2023, 04:11:18 am »
more
  • Country: cn
« Reply #2 on: December 24, 2023, 05:55:57 am »
Rise Time (70MHz version, no hack)  2.34ns 3.4ns
Edit: To see the "Real" rise time with flatten-top signal input, scroll down.
« Last Edit: December 24, 2023, 08:39:39 am by PELL »
The following users thanked this post: Someone, egonotto
  • Country: cn
« Reply #3 on: December 24, 2023, 06:21:12 am »
White Noise input, check frequency repone. I wonder why there is a bump at 300MHz
(The second picture is SDS6204)
  • Country: cn
« Reply #4 on: December 24, 2023, 06:37:49 am »
Port scan:
PORT      STATE SERVICE      VERSION
21/tcp    open  ftp          vsftpd 3.0.3
80/tcp    open  http         lighttpd 1.4.58
111/tcp   open  rpcbind      2-4 (RPC #100000)
5024/tcp  open  scpi-telnet?
5025/tcp  open  scpi-raw?
5900/tcp  open  vnc          VNC (protocol 3.8)
49192/tcp open  unknown      1 (RPC #395185)
Service Info: OS: Unix
  • Country: cn
« Reply #5 on: December 24, 2023, 06:39:50 am »
85ps fast edge, flat top input, front end response:
Three machines: 70MHz sds800x hd, 2GHz sds6204, "10GHz Lecroy"
Edit: The Lecroy photo was taken quite a long time ago, he forgot the bandwidth of it :palm:
But he told me the Lecroy has 40GSa/s samplerate, according to the rise time it measured, I assume this is an 8 or 13G model.
« Last Edit: December 24, 2023, 08:46:00 am by PELL »
Offline rf-loop
Re: Siglent New SDS800X HD First Bactch Unboxing And Tests!
« Reply #6 on: December 24, 2023, 08:03:27 am »
What is the purpose of such "tests".
If the purpose is entertaining, yes, that's fine.  ;)
For example, the measurement of rise time without a flat top is... all know..
Then Rigol noise is measured using AC RMS but Siglent noise is measured using (True)RMS.
For compatability, Siglent noise measurement need use Stdev measurement instead of  (True)RMS because true RMS also include DC offset. In Siglent,  Stdev is for measure "AC" RMS.  (In practice there is always some DC offset in system what is included in RMS)
Btw, the SDS800 frequency response FFT image ... is ... an analog filter before the ADC, but then (obviously ;) ) there is also a digital filter after the ADC. (it can also see and deduce from that FFT image, because this BW shape would not be possible (at least in practice) to do it in the analog front end of an oscilloscope... see this bw shape)
Let's return back to these and many others when can release real, carefully and somehow seriously made real tests what meet the basic requirements.
Thanks for these pictures though. They were quite entertaining and funny.  :D
I wish a merry and happy Christmas!
« Last Edit: December 24, 2023, 08:05:48 am by rf-loop »
The following users thanked this post: Performa01, egonotto, 2N3055, PELL
  • Country: cn
« Reply #7 on: December 24, 2023, 08:27:07 am »
Yes it is. We are very excited and have lot fun to see how this new entry-level performs at some extreme conditions. ;)
Thanks for pointing it out.
So that's why I attracted another 3 images of flat top signal response. :D The real rise time should be around 3.5ns.
Thank you!
« Last Edit: December 24, 2023, 08:42:59 am by PELL »
  • Country: cn
« Reply #8 on: December 24, 2023, 11:15:36 am »
Funny... My friend told me they found an unusual internal noise peak on SDS6204.
They expect to see a pretty much flat noise floor when input terminate with 50ohm. but that's not the case on SDS6204 (look at the pictures), you can see many peaks in the picture.
Notice: I am just statement the fact they found on SDS6204, no personal opinion. And I know nothing about how the peaks formed. They plan to report it to Siglent.
« Last Edit: December 24, 2023, 11:19:23 am by PELL »
Offline Martin72
  • Testfield Technician
« Reply #9 on: December 24, 2023, 01:02:16 pm »
Nice pictures, but you can only really test/compare something 1:1 and in "real life".
And a comparison requires the same conditions, otherwise it won't work anyway.
That's why I'm going to keep my DHO for now, just in case the 800X HD is the model that will be released here in 2,3 months.
Then I'll have it too. ;)
Edit:
@PELL:
SDS6000 things can be better posted here:
https://www.eevblog.com/forum/testgear/siglent-sds6000-pro-10-and-12-bit-dso-coming/msg5166129/#msg5166129
« Last Edit: December 24, 2023, 01:04:32 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: egonotto, tautech, PELL
  • Country: cn
« Reply #10 on: December 24, 2023, 01:08:11 pm »
Thanks!
Offline Fungus
« Reply #11 on: December 24, 2023, 01:30:01 pm »
As a Rigol owner I have to say those traces look quite thick.
And the UI looks primitive.
Online 2N3055
  • Country: hr
« Reply #12 on: December 24, 2023, 01:35:28 pm »
Such a classy and eloquent statement!!
You have nothing else to say coming here?
Something actually relevant?
Offline JPortici
« Reply #13 on: December 24, 2023, 04:32:56 pm »
You just don't understand, it doesn't have that vintage android 2.3 look.
just add him to the ignore list and forget about it
The following users thanked this post: 2N3055, KungFuJosh
Online 2N3055
  • Country: hr
« Reply #14 on: December 24, 2023, 04:36:20 pm »
You know what, you are correct on both points!!
Thank you !
Merry Christmas!!
Offline Fungus
« Reply #15 on: December 24, 2023, 06:46:29 pm »
It's an "unboxing", so.... first impressions: Thick traces and a pixelated font.
Don't tell me you looked at that screenshot and said "Wow!"
and what's with the silly text?
And that table of peaks? Ew!
« Last Edit: December 24, 2023, 06:48:59 pm by Fungus »
Offline KungFuJosh
  • TEAS is real.
« Reply #16 on: December 24, 2023, 07:05:43 pm »
My first impression when I saw this screenshot was mediocre graphics with 20 year old gradient designs; somehow both pixelated and unclear; plus wasted real estate for bad Rigol logos. 2004 is calling, they want their lame tab designs back.
Offline Veteran68
« Reply #17 on: December 24, 2023, 07:16:32 pm »
As an owner of a DHO1074 and a longtime software engineer, I concur. I much prefer the Siglent UI.
Don't get me wrong: For what I paid for the DHO on the BF sale, it's a helluva bargain and I'm not disappointed in it at all. But if/when Siglent releases their 1000HD series at a price point approaching the DHO1000 (MSRP, even), I'll most likely sell the DHO and buy the Siglent.
The following users thanked this post: Performa01, 2N3055, KungFuJosh, zrq, PELL
Offline sonpul
  • Country: ua
« Reply #18 on: December 24, 2023, 07:35:09 pm »
The main reason why I will not consider buying Rigol DHO is the interface.
And today's images of Siglent only convinced me of this idea. Silent, strict and laconic Siglent.
Can I reconsider my opinion, but for now I associate the entire style of the DHO interface with this screenshot. And this is unbearable for me.
« Last Edit: December 24, 2023, 07:37:34 pm by sonpul »
Offline Fungus
« Reply #19 on: December 24, 2023, 07:45:10 pm »
You can argue about the color gradients but there's no excuse for the pixelated fonts.
The text readability on the Rigol is awesome.
The windows are really useful.
Offline Veteran68
« Reply #20 on: December 24, 2023, 07:56:50 pm »
I'd argue with you.
The Siglent fonts are entirely readable. The Rigol fonts are able to take advantage of built-in font handling and smoothing built-in to Android. Siglent uses their own custom OS/graphics and evidently did not see the need to write their own font smoothing algorithms, and I can't say I blame them. Quality of Siglent software overall has always felt more solid to me.
Rigol makes some excellent hardware, no doubt. I love the big, crisp screen on the DHO1074, and likely wouldn't trade it in for the smaller screen of the SDS800X. That's why I'd be holding out for a comparably priced 1000X HD.
Rigol took a shortcut in using Android, and I have no problem with that either -- as long as the OS is stable and the scope software written for it is rock solid. I much prefer Android it to the old scopes running embedded Windows and floppy drives. But Rigol's scope software feels pretty much beta quality compared to Siglent.
All that said, kudos to Rigol for being first to market in this affordable 12-bit space (much as they were with the DS1054) and no doubt pushing Siglent to compete. I'd argue they both (as well as their respective fanboys) have something to learn from each other with regards to the entry/hobbyist market.
The following users thanked this post: Performa01, 2N3055, PELL
Online tv84
  • Country: pt
« Reply #21 on: December 24, 2023, 08:25:20 pm »
You definitely beat the hell out of tautech in selling Siglents! I respect your resilience but I come to the conclusion that there is no better Siglent salesman in this forum as you.
(I admit that sometimes you also sell some Rigols. :) )
Merry Christmas to the Forum!
The following users thanked this post: Performa01, Martin72, Antonio90, PELL
Online 2N3055
  • Country: hr
« Reply #22 on: December 24, 2023, 08:28:12 pm »
Merry Christmas to everybody!
The following users thanked this post: Performa01, egonotto, Antonio90
Offline Martin72
« Reply #23 on: December 24, 2023, 11:34:37 pm »
That's funny, I particularly like the user interface of the DHO, I like it when everything important can be selected at a glance and you don't have to get lost in sub-sub-sub-menus or scroll to find all the functions of the respective menu.
You can argue about the graphic design, but that's secondary, at least for me.
Quote from: Fungus
You'd think you hadn't had/tested many scopes as often as you throw around superlatives about the DHO. ;)
Text is rather unimportant for a device that is supposed to display signal curves.
Yes and no.
First of all, you have to respect the fact that Rigol has introduced something like this in this price range - unique.
But as is almost always the case with Rigol, not consistently thought through to the end.
These windows have fixed positions at which they can be moved and fixed sizes that cannot be changed.
« Last Edit: December 24, 2023, 11:59:00 pm by Martin72 »
(Kierkegaard)
Offline Fungus
« Reply #24 on: December 25, 2023, 12:08:22 am »
And show numerical information about those curves.
You yourself said you like the colors of the Rigol's table views.
