Tested the new EasyDMM:
Version Tested: V100R001B01D01P05
OS Used: Windows 10 Pro 64bit
VISA drivers: NI Visa Shared Components v.5.6.0
Meter/Firmware used: Siglent SDM3055 with P01.16R2.
Fixed (compared to EasySDM v1.1.1.2) :
+ Screen update problem in the upper part of the display
+ Change Histongrom --> Histogram
Not fixed (compared to EasySDM v1.1.1.2) :
Major (new)
- Pressing Shift/Local on the SDM3055 will show the reading on the actual display of the meter, however after doing this changing range (e.g. from DCV-->ACV) on EasyDMM leads to "Program Not Responding" so application hangs and needs to be killed. SDM3055 stays at connection status (Top Right) "Remote" and also does not respond anymore until EasyDMM is killed and then goes to connection status "Local".
Medium (new)
- Pressing Run/Stop on EasyDMM will set SDM3055 from trigger status (top left) "Immed Trig" {green color} to "Stopped" {red color} and the measurement reading is shown on the actual display of the meter. Pressing Run/Stop on EasyDMM again will show trigger status "Immed Trig" {white color} on SDM3055, so in white color instead of (previous) green color and also does NOT blank out the (previous) measurement reading on the actual display of the meter back to ".. ....." (like it was before pressing Run/Stop). (a work around is to switch the range and switch range back)
- The Rel On/Off on EasyDDM is shown on the 5th function key whereas this function is implemented and displayed on the 6th key of the SDM3055 meter (may be minor, but I find this annoying)
- The Range button on EasyDMM is only there for show there is no functionality. You cannot set "Manual" range like on the SDM3055 meter. You can however use the 1st function key in EasyDMM to select Auto or a specific range (e.g.2V, 20V etc) but not toggle between Manual and Auto. The + and - range buttons are also there for show and do not function as the SDM3055 meter. (may be minor, but I find this annoying)
Minor / Cosmetic (new)
- Branding "Siglent" on the Top Left of EasyDMM is now blank instead of the nice Siglent Logo of the previous version (branding guys, I know that is important !!)
- Branding "SDM3055 Digital Multimeter" on the Top Left of EasyDMM next to the Siglent Logo is now blank instead the previous version
Minor / Cosmetic (already reported)
- Change 'Scaner' text above 'Temp' button on the picture to 'Scanner' (typo)
- Change UI colors on the screen to match those on the real SDM3055
- Change the Led color on the left from red to green (like on the real SDM3055)
- Change '2nd' button on the picture to 'Dual' (like on the real SDM3055)
- Add text "Display" above the "Math" button on the picture (like on the real SDM3055
Overall I am happy with the new version, but I hope the Shift/Local bug will be fixed soon.
