Time to drag the translator out and compare the Chinese FW release notes with those for SDM3045X.
SDM3055X-E 软件版本修订记录及升级说明.zh-CN.en.pdf2021/7/6 2.01.01.12
1. Add the memory recall function of the scan card configuration
2. Increase the switching time interval of the scan mode card channel to avoid common faults.
3. Crashes when loading files of different models, and the file path is abnormal after secure erase
4. Some UI (slow refresh in fast mode, not enough digits, incomplete display, etc.)
Bugfixes related to SCPI commands
2021/2/5 2.01.01.10R1
1. Modify the individual crash problem of U disk storage
2. Modify some defects of the acquisition function
3. Improve the trend graph display function
4. Fix some bugs in communication with EasyDMM
SDM3055 Firmware Revise History and Update Instructions.pdf2021/7/8 1.01.01.25
1. Add the scan card setup save&recall function.
2. Optimize the slot time of the channel switching of scan card.
3. Optimize flash R&W design.
4. Fix some UI & SCPI bugs
2021/2/5 1.01.01.22R1
1. Fix some unit faults of 22 version.
2. Fixed some bugs about communication with Easysdm
SDM3045X-Firmware-Revise-History.pdf2021/9/22 5.01.01.07R1
1. Add the customer sensor support.
2. Optimize flash R&W design。
3. Fix some UI & SCPI bugs
2021/2/5 5.01.01.06R1
1. Fixed some unit faults in 06 version
2. Fixed some bugs about communication with EasyDMM.
