I know there’s a whole DIY thread on building your own probes in place of the SPL2016 logic probe set, but I haven’t been able to find anyone talking about how well the SDS2000X Plus ultimately works as a logic analyzer?
Does Siglent’s weird memory management effectively mean that it uses segmented memory?
Basically I’m trying to figure out whether for $400 I’m better off with the 16 channels on the scope or 8 channels with a Salae logic analyzer.
It depends entirely on your use case. I can't tell from your message above whether you already have an SDS2000X+ series scope, so the below presumes that you don't. Please don't be offended if you already know at least some of what follows.
The Siglent's memory management does indeed mean it uses segmented memory, essentially constantly. The nature of it is that what you see on the screen is exactly what you're getting in a single segment of memory, and how many segments you get depends on the "points width" of the screen (sample rate multiplied by the time covered by the screen). The upper bound of the points width of the screen can be set via the memory depth setting, and if you set that to a lower value than the maximum amount of points the scope supports then the number of segments you can capture will be at least the maximum points divided by the configured memory depth. Of course, it can be more than that if the amount of time represented by the screen is sufficiently small that the maximum sample rate of the scope can't fill the configured memory depth.
Maybe it's simpler if I give examples.
The 2000X+ has 10 divisions across. Suppose you're using 2 analog channels in the same bank, so your maximum samples per channel is 100M points. Let's suppose that you set the memory depth to the full 100M points. With that setup, the maximum sample rate is 1G S/s.
If you set your time per division to be 100 ns, the screen width time would then be 10 times that, or 1us. At 1G S/s, 1 us worth of time is 1000 points. In the absence of per-segment overhead, that would get you 100K segments that you could capture. In reality, it'll be less.
Now let's presume that you set your timebase to 10 ms. The screen now represents 100 ms worth of time. At 1G S/s, that translates to 100M samples. That eats the entirety of sample memory, so you only get one segment.
Now you drop the memory depth to 10M samples. Because 1G S/s would fill that number of samples in 10 ms, but your screen width represents 100 ms, the scope has to cut the sample rate to a tenth of its maximum, or 100M S/s. But now you have 10 segments.
The SDS2000X+ series has a zoom function that works very nicely. The size of the screen allows for this. This means that you can configure the scope's time width to match your acquisition needs
and configure the zoom parameters to match your display needs, simultaneously.
The Siglent's approach to memory management gives you two advantages. The first is the complete absence of ambiguity. What you see on the screen (in the top portion in zoom mode) is exactly what you're going to get. The second is the always-on nature of segments, which means you can
always go back and review previously captured segments. If you're capturing messages on a bus, this can be quite handy because you can set up your trigger to capture the message start, set up the display width to capture an entire message, and just go. When you stop the scope, if you captured multiple messages, you'll be able to review as many as the number of available segments allow. And each segment will be fully decoded by the scope, on demand (you can perform the capture and then configure the decoder to show the translation, after the fact).
If you're used to other more traditional digital scopes that capture more than just what's on the screen, this approach may take a bit of getting used to. But you may find that you prefer it after you've worked with it a while, precisely because it eliminates a lot of guesswork and ambiguity that would otherwise be present. And just for the record, most other scopes will also capture only what you see on the screen if the timebase is set long enough. It really depends on where your operational focus is. With the Siglent, the focus of the capture is on time. With other scopes, that focus is on memory depth. Time is arguably what you work with more directly and more often, so it is arguably the more appropriate parameter to design a capture system around. But it really is a matter of personal preference in the end.
That said, for logic analysis, the Saleae might well be better. I can't honestly say. It depends on how you're going to use it. The scope is useful for seeing the analog side of a digital signal, to do things like check for signal integrity and such, but the digital channels give you a lot more to work with for complex digital devices. The Saleae's decoding might well be better or more flexible. The Saleae's sample rate is much lower than the Siglent's digital channels, 100M S/s for the Saleae versus 500M S/s for the Siglent. But on the other hand, the Saleae has a buffer that's probably limited by the computer you're on more than anything else, whilst the Siglent has a buffer of 50M points maximum per digital channel (this scales with the analog channel memory depth in relative terms. If you set the analog depth to 20M points out of 200M points, the digital channels will likewise be set to 5M points out of 50M points, in order to keep the minimum number of available segments the same for both).
In any case, hopefully the above sheds some light on how this works. The SDS2000X+ series is a pretty amazing bit of kit, but there are certainly going to be situations in which a dedicated logic analyzer is a better tool for the job.
There exist ultra-cheap Saleae logic clones out there that you might try first before making a real decision about the Saleae. And honestly, if you're on the fence about the Siglent logic probe, I'd probably go with the DIY variety to start with, if only to see for yourself how well it can work for you, presuming it's an option for you at all.
One other thing: I don't know if the Saleae has any sort of segmented memory, but for certain use cases its absence can be a serious drawback. That, along with the wide variety of triggering options on the Siglent (including, of course, the ability to trigger on
analog events while capturing digital data), may give the Siglent approach a significant advantage. It's something to consider, at least.
