I "still" have the SHS 1062 ...
... I reported some Frimware issues here
https://www.eevblog.com/forum/testgear/siglent-technical-support-join-in-eevblog/msg579658/#msg579658... they made a new Firmware "3.01.02.02R2" ... I think the only thing they changed was the version number ...
So, the scope is still just in short memory usable (10K). The long memory (2M) still does not work in any usefull way.
Just in short memory the scope works well so far ... also at least 4 or 5 hours on battery.
The recorder functions also work, sadly I any of them you can zoom in later. But you can save up to 2700 ("unzoomable") single shots in recorder mode. While the functions works well ... sadly you just can save 1 channel. But at least you can trigger on the other channel.
The probes supplyed with the SHS1000 series are Isoprobes from Multi-Contact
http://www.multi-contact.com/products/hfline/1. They are the "original" Fluke, Agilent Handheld and Chauvin Arnoux probes. So you can get easy (not cheap) add ons for these probes.
Hope I could help ...
I have mine now a while ... I guess it is slowly time to cut the warranty seal and make a teardown
